Hi guys , really hope someone can help id this axle correctly for me , as i need to replace bearings and seals, on a freshly built 32 ford as the seal has gone on the halfshaft end. the axle is a bit of an oddball (but it came with the truck) it's stamped as Ford, with 10 bolt rear diff cover the axle tag number is WER V 5LD 2 75 8 7 575B. i cant seem to find anything with those numbers though i'm guessing it's a 2:75 ratio. Can anyone help please.
@bobbooth Pic , is rear from States ? Maybe later mustang , Explore . Sounds like Explore 2008 ish I think SVO mustang 2000 up , The Explorer I think 2 or 3 different third members were used If you are not aware Try Rock Auto Parts , site is easy to use. use the search or use the site for eye identification , the online site is good for spec & other identification information
