FORD PARTS - 1936 16" ford wide 5 rims- 15$ each. - 1936 wide 5 drums, brakes everything to bolt up to a spindle- 20$ each - 36 ford axle w/ spindles- 100$ SOLD - 36 Ford wishbones- SOLD - 32 FORD heavy alxe, is bent- 80$ SOLD - 20's dodge axle (pitted pretty good, could chop it up)- 20$ - 20's FORD Model T Cowl- 40$ SOLD MOPAR EARLY HEMI POLY HEMI PARTS - 1951 Desoto Hemi 270 cuin engine and trans (RUNNING ENGINE)- 500$ SOLD - 51-53 GOOD Chrysler solid roller cams from the 51 INDY500 racing program- 200$ea SOLD ONLY 2 LEFT - 51-59 Chrysler rods, 3/8 & 1/2HD rods-60$ set SOLD -2 sets left - 1956 331 complete Spitfire heads, vlv covers, manafolds (OFF RUNNING ENGINE)- 200$ - 1956 331 HEMI TORQUE CONVERTER- 20$ MOPAR BIG BLOCK PARTS - Billet aluminum mech adv distributor- 40$ - 64-67' 361/383 '516' Closed chamber heads & rocker shafts pt no. 2406732 2.08 /1.60 valves- 100$ SOLD 1 PAIR, 1 PAIR LEFT SOLD - 402 stamped center sump oil pan- 40$ SOLD - 58-71' 383 balancer pt no. 2658457- 5$ SOLD - 65' right exhaust manifold pt no. 2205535- 20$ SOLD left exhaust manifold pt no. 2461307- 20$ SOLD - 66' 440 Truck exhaust manifolds - 40$ SOLD - 65' points dist- 20$ SOLD - Good 65' 4bbl cam and hyd lifters (engine rated @ 330HP)- 20$ SOLD - Edelbrock Performer 383 4BBL aluminum intake- 60$ SOLD - A body 8.75 axles with new green bearings & seals- 180$ SOLD - 8.75 741,742,489 center sections- 100$ + SOLD THE 742 &489 - 6 good Chevy 6.535 440 Source I beam rods w/ 2.20 x 0.990 ends- 25ea (use in a Mopar B/RB with a 4.25 crank to get 496cubes) - 58-61 Wieand WPD 39 Tri Power w/ Rochester 2GC carbs for 361-400 B series engine, pulled off a running engine several years ago- 1000$ REBUILT AND ON A RUNNING ENGINE NOW READY TO BOLT ON 440 SIX PACK- 1900$ CAME OFF A RECENTLY GRENADED ENGINE WITH ONLY 1500MILES ON IT! STILL BRAND NEW! - ORIGINAL Edelbrock DP6B B series low deck 6BBL intake (there hard to find these days) - Holley 440 6BBL carbs (all matched 1970 440) - 69 1/2 Fresh Air base& top + filter for a - Carb linkage - Fuel line 1950 DODGE WAYFARER D33 FRAME - 2 front crossmembers in good shape- 60$ea - rear axle- 100$ SOLD - stock steel rims- 20$ea SOLD - flat head 230cuin radiator- 20$
ENGINE PARTS PICS Phttp://www.jalopyjournal.com/forum/threads/mopar-383-b-low-deck-engine-parts.926271/
