Technical Ford backing plates
Discussion in 'Traditional Hot Rods' started by mercjoe, Feb 14, 2024.
  1. mercjoe
    mercjoe
    Hi everyone,
    I'm putting together F1 backing plates/ drums with Ford p*** car 46-48 spindles.
    Any idea which bolts and nuts should I get and where to get them from ?
    Thanks for any help !!
    Mercjoe
  2. pprather
    pprather
    The bolts that attach backing plate to spindle?
    1/2" fine thread grade 8?
    mercjoe likes this.
  3. mercjoe
    mercjoe
    Yeah. The ones attaching then pindles to backing plate !!
    Are those the specs for the bolts ? I have no idea really cause I lost mine.
  4. seb fontana
    seb fontana
    from ct
    Don't think you need or originals were/are grade 8 but it wouldn't hurt. Any old Ford parts supplier would have them, probably Macs, Rock auto, summit, speedway...
    mercjoe likes this.
  5. flthd31
    flthd31
    Originals look like the pic below. The square head fits against a ridge on the spindle to keep it from turning. Plus the shoulder makes it a tight fit. I would try to get some originals. Shouldn't be too hard to find. Also these bolts have a hole for a cotter pin to be used with a castellated nut.
  6. seb fontana
    seb fontana
    from ct
  7. pprather
    pprather
  8. mercjoe
    mercjoe
    Cool, thanks guys.
    Is it worth getting those originals ? Or will other bolts with the right measurements do the job just as goos or even better ?
  9. jimvette59
    jimvette59
    The square head is there to stop the bolt from turning when you tighten the nut. Get them. JMO
    warbird1 likes this.
