I scored two Model A rear ends at the weekend. As part of the haul there is the internals from a 32 rear axle - is it possible to use these within the A casings - Also did a seach re juice brakes on the rear of the A - what is the easiest upgrade - will be behind a standard flathead (8BA) powered modified
You can mix 32 and A parts in the rear end. ***uming you don't have the rare late 32 style. Bells will fit. Any juice brake set ups will work. You might try installing the backing plate upside down and turning the w/c back up. The spring mount interfears with the backing plate.
