Technical Ford brake adjustment?
Discussion in 'The Hokey Ass Message Board' started by Never2old, Jun 5, 2018.
  1. Never2old
    Never2old
    from so cal
    So I've looked at several posts on how to do it but I'm still baffled.
    First what year brakes do I have , and how is it done?
  2. Mr48chev
    Hard for anyone to tell without seeing the whole backing plate.
  3. 117harv
    117harv
    Those are 46-48 brakes, there is no lower adjustment.
    dana barlow likes this.
  4. Never2old
    Never2old
    from so cal
    Okay, I am chasing a problem of too much pedal travel, so I thought I needed more adjustment on the front brakes.
    The rears are tight and the park brake works fine.
    I have residual pressure valves on both front and rear lines and a 1" master cylinder.
    The pedal is not soft at all but requires a heavy foot.
  5. 19Fordy
    19Fordy
    Looks like someone sawed off the bottom of the spindle? Wonder why?
  6. RICH B
    RICH B
    Their are two adjuster bolts higher up on the backing plate; one front and one rear. Put an 11/16" wrench on the front so it is stick forward, push down on it until you can't turn the wheel, then back off so it just turns free. Put the wrench on the rear bolt so it faces rearward, again push down on the wrench until the wheel won't turn. Same procedure on the other side; followed by a test drive.
  7. RICH B
    RICH B
    Probably got happy cutting off the arm.
  8. 19Fordy
    19Fordy
    You said you are using a residual valve which makes me think it's not stock system.
    What year, make and model are the rest of the braking system?
    Do you have drums on all 4 wheels or just two?
    Do you have Bendix or Lockheed style brakes?
    What year, make and model master cylinder?
    Do you have discs on rear? Give us all the info. you can with photos.
  9. F&J
    F&J
    it is not cut off. not sure what you are seein' lol..
    First time out driving? New shoes? New or old drums? Did you set each shoe in each drum to check to see if the radius of the shoe matches each of all four drums?
    If the radius is wrong, you only will see a small wear spot on each shoe after driving it for the first time. (if you pulled the drums off to look) So, if you had little contact area, it won't stop for chit...
  10. Never2old
    Never2old
    from so cal
    Mustang 8" drum rear, Corvette M/C.
    Upper adjusters were done.
  11. Never2old
    Never2old
    from so cal
    I suspect the pressure valves aren't working.
  12. X38
    X38
    Is it a drum/drum m/c?
  13. 19Fordy
    19Fordy
    "It is not cut off. not sure what you are seein' lol."
    You can see the hacksaw marks. Plus the king pin isn't suppose to "stick out" like shown..
  14. 19Fordy
    19Fordy
