ford c-4 with merc 256?
Discussion in 'The Hokey Ass Message Board' started by Bryan, Jan 22, 2004.
  1. Bryan
    Bryan
    I posted this in the questions forum, and I figured I'd post it here too,
    Anyone know if this would work out, or more specifically, what would be needed to mate these? I'm looking into a merc that has a merc-o-matic thats about ready to die.
    again, any help or advice is always appreciated.
    Thanks in advance
  2. Flatdog
    Flatdog
    Is it the same as a 368 lincoln?
  3. enjenjo
    enjenjo
    from swanton oh
    Flatomatic makes a kit for this.
  4. Ted H
    Ted H
    Check with Gene Benson at www.flat-o-matic. com
    he makes adaptors to fit the flat v8 to a c4 or a T5. He also makes adaptors to fit the same trannies to the Ford Y blocks.Gene is a hotrodder himself and really knows his stuff.
    Ted H
  5. 286merc
    286merc
    from Pelham, NH
  6. AnimalAin
    AnimalAin
    Speedway Automotive markets one, as well. C-4 has to be more efficient than your old automatic; lighter, too.
  7. Digger_Dave
    Digger_Dave
    [ QUOTE ]
    [/ QUOTE ]
    Just a "heads up" on the Speedway C4 adaptor. It will ONLY work with POST '49 flatheads. (NO rear bell housing)
    The adaptor is a flat plate that bolts to the rear of the engine, and the ORIGINAL C4 bell housing is used.(it's big)
    A late model starter is used (moving pole type) which requires a fair amount of grinding on the block for clearance.
    Flat-O-Matic's adaptor can be used on any flathead from '32 to '54, keeps the flathead starter, comes with a new bell housing (much smaller than stock) and a new tourque converter.
  8. Deyomatic
    Deyomatic
    from CT
