COE Ford C series
Discussion in 'Off Topic Hot Rods & Customs' started by jgang, Feb 13, 2020.
  1. jgang
    jgang
    from hamburg ny
    I was just wondering if anyone has done a 1957-1990 ford c series coe. Thats my favorite coe cab and im getting started on my project and lookin for some ideas. thanks a million.
  2. Not my cup-o-t, (too big and boxy) but here are some pics. Seems race car hauler is a common theme
    c1.jpg c2.jpg c3.jpg c4.jpg c5.jpg c6.jpg c7.jpg c8.jpg .
  3. jgang
    jgang
    from hamburg ny
    i spoke with the fella who built the yellow pickup... said he did it on a ranger ch***is.
  4. Looks like he has extreme positive offset wheels, I'll bet that handles great!:eek:
  5. RMR&C
    RMR&C
    from NW Montana
    That's one COE cab that would work good on these late model too wide ch***is swaps...
    vintage56 likes this.
  6. HJmaniac
    HJmaniac
    I thought this would interest you guys, Carroll liked it. ;)
  7. HJmaniac
    HJmaniac
    Mack used the Ford cab on their Model N
  8. HJmaniac
    HJmaniac
    FWD used them too.
  10. HJmaniac
    HJmaniac
    This might help you with details.
    BTW it is For sale Because of health reasons.
    Not Mine saw on interweb
    http://smcl***iccars.com/ford/64408...ct-rat-rod-street-rod-rat-rod-truck-semi.html
    Description for Ford C700 1961
    1961 FORD C700 Custom Cabover Project, Rat Rod, Street Rod, Rat Rod semi truck,
    .Custom built frame, 2x6 1/4" thick steel.All supports & cross members, 2x2 3/16" thick.Engine, 5.9 ***mins Turbo Diesel with an Allison transmission 107,000 miles, came out of a 1997 Thomas Bus.All axles are a four link suspension with 9 1/4" lift airbags.Drive shaft is custom built and installed.Radiator and inter cooler installed and hoses are done.2 large fuel tanks with straps, 1st tank is 150 gallons, 2nd tank is 130 gallons, primary tank is a 16 gallon Keg.Holland FW35 5th wheel.Dodge front axle is a 3500.Dodge front axle on rear is a, Dana 80.Chevy 10 bolt on rear axle, new brakes, new drums, and seals.6 new gray rims.New front tires, Cooper Discover HT LT 225/75R16 load range E.New back tires, Corsa Highway Terrain LT 225/75R16 load range E.Rear bumper, 12 4" LED brake lights and turn signals, 50 red LED 3/4" lights on rear bumper.Front bumper, 3/4" LED yellow and green lights, side lights underneath fuel tanks are yellow and green.Cab is very clean inside, white interior
    Things that you need to do to finish truck:
    .wiring.brake master cylinder and brake lines to all axles.exhaust.watts link on front axle.fuel lines.steering gear box and linkage.gas pedal linkage.transmission linkage.front brakes and rotors.air lines, air tanks, and air compressor
