Ford c4 Pan fill/case fill trans.
Discussion in 'The Hokey Ass Message Board' started by George/Maine, Jan 6, 2011.
  1. George/Maine
    George/Maine
    I have a TIC torque convertor "Sat night special "and says use with pan fill trans.
    I have 2 case fill trans and both bellhousing large and small.The torque convertor is 11 1/2 pattern.
    Small one most likey to small but can,t see why i can,t use the larger one with case fill. Any info Thanks.
  2. I think I would call TCI and ask them....
    I'm sure they will have an explanation
  3. 1957Custom
    1957Custom
    from Tulsa Ok
    The only difference would be the input shaft if one of the case fill transmissions are early. If they are all 28 spline they will interchange. I run a C-4 in my race car & went from a case fill to a pan fill, no problems
  4. According to TCI there are 24 Spline and 26 Spline. The other difference is bolt circle diameter, 10.5" and 11.4"
  5. George/Maine
    George/Maine
    I checked the splines and are the same, 1981 trans.
  6. 1957Custom
    1957Custom
    from Tulsa Ok
    If the splines are the same & the snout fits the back of the crankshaft, you are OK
  7. And the bolt pattern fits the Flex Plate .....
