I got a Ford engine and Iam trying to find out for sure what it is,a 302 or a 289 the numbers above the starter are D10E-6015AA. Do any of you Ford guys know what this is.I tried one Ford site and all it said was some **** about a tag on the engine,when is the last time somebody left the wired on tag on a motor this old? help me out if you can,Thanks
D1 would indicate first engineered/produced in 1971 but could have produced for several years with that number.......very likely a 302 Ray
Yep i's a 1971 or later 302 . Also take the valve covers off and see what the head is stamped . Another good place is in the valley under the intake . It will have a 289 or 302 there also . Jim
1971 302, Torino Fairlane. New block came out in 72 (D2 #) so it is most likely a 1971 only motor D = 1970 1 = 1 (which makes it 1971) O = Torino/Fairlane E = Engine 6015 = engine block AA = 302
D1OE 6015-AA is a 1970-74 302 block . 70-72 had a 8.206 deck height and the 73-74 had a 8.229 deck height. It is a Fairlane/Torino block. Is there a aluminum tag under the coil.
