Ford Engine Numbers
Discussion in 'The Hokey Ass Message Board' started by 3's&8'sHigh, Nov 9, 2010.
  1. 3's&8'sHigh
    3's&8'sHigh
    Just picked up a '59 Thunderbird and I'm trying to figure out what some of the engine codes mean. The guy I bought it off of said the motor was a 1966 390.
    Water Pump - C8AE
    Heads - C7AE-A
    Block (next to the starter) - 66ME-A
    I really appreciate any help you could offer or any tips.
    Thank you for your time.
  2. metal man
    metal man
    Don't recognize the block#,but the heads are 67. C is for sixties, 7 as in 67.That's all I got.
  3. 53 effie
    53 effie
    It's likely that block casting is actually C6ME-A. If the heads are C7AE-As and are original, it is likely a 67 motor. Water pumps often get changed over the years and may not match numbers wise. You'd have to get the date codes off all the major casting to find out exactly what year motor you have.
    Based on what you gave, again I'd guess a '67.
  4. squirrel
    what he said. double check that 66ME-A number, see if it's really C6ME-A which is the casting number for a 66 or so 390 block.
    The exact date is hard to tell from the casting numbers, as is the size. There are casting date codes on some engines, look for a number-letter-number sequence such as 6E15 and you may need to measure the bore and stroke to be sure what the displacement is.
  5. 3's&8'sHigh
    3's&8'sHigh
    Thank you all for replying, I appreciate the input.
  6. TimeWarpF100
    TimeWarpF100
    as someone said most likely a 67 engine. I have 4 C6ME-A blocks and are all 352's
    Just look for the block date code which is cast in block near the oil filter adaptor
  7. 1957Custom
    1957Custom
    from Tulsa Ok
    My C6ME was a 390 GT. It's a Mercury part number
  8. 3's&8'sHigh
    3's&8'sHigh
    Thanks again for all your help.
