Hot Rods Ford F-1 sector shaft repair
Discussion in 'The Hokey Ass Message Board' started by Larry91739, Apr 4, 2019.
  1. Larry91739
    Larry91739
    I haven't scrutinized it yet but it looks like the grease seal has worn a groove in the shaft.
    Anyone know of a company fixing this kind of damage? (I'm guessing weld and machine
    smooth type of operation)
    Thanks.
  2. alchemy
    alchemy
    Not a high speed item. Are you sure a fresh seal wouldn’t do the job?
  3. Doublepumper
    Doublepumper
    from WA-OR, USA
    Might be able to shim behind a new seal to get it out of the groove, or replace the shaft. I wouldn't be welding on it...not safe.
  4. 34 chevy
    34 chevy
    from michigan
    HI, how about building up the worn area with epoxy and sanding it down to match the unworn area of the shaft? good luck.
  5. Companies like National seal make thin metal sleeves to go on shafts that have a worn groove.Most commonly used on harmonic balancers to save them,but they come in many sizes.A google search should turn up something,or a good counterman at a bearing house.
    36-3window likes this.
  6. Install a new seal and fill the box with J. Deere corn head grease.
    cactus1 and sidevalve8ba like this.
  7. Larry91739
    Larry91739
    I work for a bearing manufacturer so I'm aware of "redi-sleeves / speedi-sleeves" and the process.
    I may be able to position the seal at a different height by machining the seating area higher but haven't
    looked closely at my exact situation. The sector shafts themselves are a pricey deal NOS, if you can find one....
    Just looking at my options.
  8. Larry91739
    Larry91739
    Thanks for the replies.
    I ended up getting a NOS sector shaft.
    bct likes this.
