Ford F-100 pitman arms
Discussion in 'The Hokey Ass Message Board' started by Roadsters.com, Jan 4, 2009.
  1. Roadsters.com
    Roadsters.com
    The shorter of these two pitman arms came off of one of my '56 F-100 steering boxes, and the longer was on a front end that I was given without knowing what year truck it was from.
    What years of F-100s had the longer pitman arm like this?
    Has anyone here used a longer arm on a '53-'56 F-100 steering box in their car?
    Dave
    http://www.roadsters.com/
  2. jetmek
    jetmek
    just a guess but maybe its off a big truck like an f5 or sumthing?
  3. duste01
    duste01
    f350 and up...yep
  4. alchemy
    alchemy
    Pretty sure the sector shaft is bigger diameter on the big trucks too. Is that so on your example?
  5. Roadsters.com
    Roadsters.com
  6. alchemy
    alchemy
    The one has a longer, meatier shaft, with a bigger ball too. I would have guessed the sector was bigger also.
  7. NealinCA
    NealinCA
    Maybe 57-60 F-100...they used a similar steering box.
    Neal
  8. v8muscle
    v8muscle
    Looking at a 56 Truck Parts Manual, the longer one fits F350, F500 truck and bus, and F600 truck and bus.
  9. manyolcars
    manyolcars
    The shorter one gives you quicker steering
  10. fab32
    fab32
    I would think that just the opposite would be true. The longer on should give you quicker steering, also further travel of the drag link.
    Frank
  11. PASTDUEBILL
    PASTDUEBILL
    I have the 3590 (longer arm). It came on a 32 ford box and column. Does the ball face in or out? Also, is it safe to use on the 32 box? It only has about 10 splines on the bottom.
    The 32 shaft does not appear tapered.
  12. qzjrd5
    qzjrd5
    from Troy, MI
    Maybe, but I thought the '57 had a tapered hole on the bottom to connect to a conventional tie rod for the drag link instead of the ball?
    Mike
