SOLD!, and NO LONGER AVAILABLE. Thank you Bob. For Sale: Complete front brake drum and hub ***emblies from a 1952 Ford F1, 1/2 ton pickup. I picked up a front suspension ***embly from a restored 1952 Ford 1/2 ton pickup for a project I am working on. The previous owner was switching the truck over to a Mustang II IFS and didn't want or need it laying around his shop getting in his way. For my project I am converting over to disc brakes so these original brake and hub ***emblies are for sale. The brake components as shown in the photo are all brand new. This includes the pads, springs, wheel cylinders, rubber brake lines, etc. The drums had even been recently turned as well. There is some rust on the inside surface of the drums from the suspension sitting outside the previous owner's shop and getting rained on. This rust is only surface rust and will clean up just fine. Also included are the backing plates, brake drums, grease shields with bolts, front wheel hubs with bearings and lug nuts, and dust caps as well. I don't know for sure if the hubs or the bearings in the hubs are new but I suspect they are as the dust caps still have some shine and the cotter pins for the castle nuts on the spindles looked new as well. These drums and hubs bolt on to any stock 1948, 1949, 1950, 1951, or 1952 Ford F1 front end. They can also be used in a number of Hot Rod applications as well. The parts are all pretty clean and could be bolted onto your application and used immediately. I am asking $300 plus the ride for the brake/hub ***emblies. Thank you for looking at my ad. Steve
