What should the timing be set at on a bone stock 63 FE 352 motor with a 2bbl? The only change is an electronic ignition upgrade. Thanks.
10-16 deg. Initial (depending on where the engine is happiest, i.e. generates the most vacuum) 36-38 deg. Total (no vacuum advance)
