Technical Ford FE 390 Vacuum not dropping
Discussion in 'The Hokey Ass Message Board' started by Haydn Glover, Oct 15, 2016.
  1. Haydn Glover
    Haydn Glover
    So after many weeks I finally got a new Vac Can and a Vac Gauge, only now, if I hook the gauge up to the full manifold on the Carb, I'm getting about 18"hg at idle but when I rev it, it doesn't drop off at all, sometimes it even goes up, so when I connect my vac advance, it doesn't drop back to initial timing when I rev it, it stays at whatever I've got my advance set to
    I'm ***uming this is most likely a vacuum leak?
  2. Relic Stew
    Relic Stew
    from Wisconsin
    If it's a no-load condition, like revving in neutral, the vacuum won't change much. The engine can freely increase revs to use all the air coming in. Try it under load, like climbing a steep hill. Should see the vacuum drop down.
  3. 1951hudson
    1951hudson
    I had a plugged exhaust system once that caused that same type of symptom
  4. deathrowdave
    deathrowdave
    from NKy
  5. Truck64
    Truck64
    from Ioway
    That's not correct. Revving in neutral, healthy engine, should show a very quick drop to around 4" of vacuum and then rebound to 25"+; this is the diagnostic characteristic of healthy rings and cylinder compression. ImageUploadedByH.A.M.B.1476546054.905585.jpg
    Haydn Glover and Andamo like this.
  6. lippy
    lippy
    from Ks
    Sounds like you need to ditch the can. Try it without it JMO Lippy
