Is there much advantage in running the first dual point crab distributor 1940-42 over the later 1942-47 single point crab distributor, i e is the extra 4 or 5 degrees of dwell worth bothering about. It seems the single point is readily available the dual point not so
I would think there isn't much advantage unless you are running modifications to the engine such as bore, stroke, dual carbs or hotter cam.
