Technical Ford Flathead 8ba carburetor
Discussion in 'Traditional Hot Rods' started by Robert Stanley, Jul 3, 2022.
  1. Robert Stanley
    Robert Stanley
    Would someone please explain the purpose and function on the economizer valve that is in the bottom of the fuel bowl. Must of looked at a bunch of them over the years cleaning carburetors and never made much sense as to why they are even there.
  2. leon bee
    leon bee
    Generally called the power valve. Something kinda like this: vacuum keeps it closed, tromp the pedal it comes open for more fuel.
  3. clem
    clem
    as said above, - also gives more fuel for under load going up hills etc…..
    Block it off if you want - ( I wouldn’t recommend to though) and see/ feel the difference.
    I tried running my tri-carb fixed linkage without PV’s and I could notice the difference.
  4. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    It adds more fuel to your mixture when your vacuum drops. Its closed at idle and opens at a preset vacuum amount. So when you are cruising along its most likely closed then when you accelerate it will open. The more air going in needs more fuel.
  5. Robert Stanley
    Robert Stanley
    Thanks to everyone responding to my question. Now I understand it's function.
    Robert Stanley
    leon bee likes this.
  6. clem
    clem
    A couple more points for you if interested.
    - When I put mine in, I sit it in place with fuel in the bowl above, and let it sit overnight to ensure that it doesn’t leak.
    - If you have a backfire through the carb, it supposedly (from what I have read on here) will blow the diaphragm in the power valve and it will need to be replaced.
    - power valves can have different ratings, standard is 7.5 for single carb flathead- and later power valves don’t always fit correctly.
    lots more info here……although some links may no longer work.
    https://www.jalopyjournal.com/forum/threads/links-to-holley-94-technical-info.286574/
