Ford Flathead-back from machine shop
Discussion in 'The Hokey Ass Message Board' started by 40FORDPU, Dec 9, 2009.
  1. 40FORDPU
    40FORDPU
    IMG_0787.JPG My engine had seized, so it was time to have it rebuilt. It is a 49' 8BA. I took it to a local machine shop, and had them put it into short block form for me, I provided all of the parts. The following was done to it:
    Deluxe de-grease (with new cam bearings installed)
    Bore cylinders .080
    Polish Crankshaft
    Balance ***embly
    Re-size rods
    Valve grind
    ***emble to short block
    New Parts:
    4 ring pistons and rings .080
    Rod bearings .010
    Main bearings .010
    Isky MAX1 camshaft, adjustable lifters, new springs, keepers
    Valves-intake and exhaust
    Timing gears
    Oil pump
    I then have/or will install the Fenton intake, dual 94's, Edelbrock heads, Fenton cast headers, MSD distributor, and MSD6 box
    I am curious what kind of horse power I can expect (I know, it is still a Flathead after all)? I will be installing it into my 40' Ford P/U
    Here are some before, and after pics.
  2. That looks *****in'!
  3. Frenchy32
    Frenchy32
    from arizona
    Was the block ready strip to remove all rust build up in and around the water jacket area. And did you have the block re surface where the heads bolt on. Looks nice
    Thanks
    Frenchy
  4. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
  5. 40FORDPU
    40FORDPU
    Thanks Frenchy, Yes it was stripped of all rust, that was a big deal for me to have done-as far as the deck surface, it was not surfaced, but was inspected with straight edge and feeler gauge, it didn't need to be done, so wasn't.
  6. Destralo Roach
    Destralo Roach
    150 HP Give or take......Roach.
  7. What is a stock running COMPLETE flathead out of a 50 mercury going for these days????? It is tired but does run and it is complete.
  8. coppertone
    coppertone
    150 screamin' gerbils, more or less. About 25 more than mine.
  9. Diavolo
    Diavolo
    There's one local on Craigslist with a trans attached to it for $1000. Wish it wasn't Christmastime or I'd have another on my garage floor...
  10. holeshot
    holeshot
    from Waxahachie
    40FORDPU...thanks for the pics, man you don't see many flatheads like that badboy. i'll bet it realy cranks, please let us know how it doe's in the 1/4...POP.
  11. Casey
    Casey
    looks great ! where did you get those carbs ?
    needs some fuel and oil spred around on it :p
    and there is no reason to surface a flathead ! it weakens the deck and threads !
    unless it is absolutely necessary
  12. hotrodtom
    hotrodtom
    "After" pix are beautiful...But I'm interested in the "before". What happened in #'s 2 and 3 that caused the pock marking in the piston tops?
    Fearless
  13. 1930roadster
    1930roadster
    Jealous... very jealous, Excellent job!
  14. 40FORDPU
    40FORDPU
    Thanks everyone for the kind words. As far as those "pock markings", those are from moisture, they were on the surface, and came right off. The block was sitting apart, awhile before I took it in.
  15. monkey19
    monkey19
    man that looks awesome!
  16. blown49
    blown49
    In Joe Abbins new book (you need to get a copy; $25.00 on his website) he dyno'ed a 255 cu/in engine with a Max1 cam produced the following with Offenhauser 400 heads:
    140 HP with an Thckston high rise & (2) 94's
    150 HP with an Eldebrock Super dual & (2) 94's
    160 HP with an Offenhauser Triple & (3) 97's
    Jim
    http://www.roadrunnerengineering.com
  17. 40FORDPU
    40FORDPU
    Thanks Jim, I will.
  18. f1 fred
    f1 fred
    from mn
  19. RAY With
    RAY With
    Nice looking flatty. I am currently doing a 304 cuin and hope it comes out as good as yours is looking. Thanks for posting.
  20. blown49
    blown49
    It's an excellent read and features 4 complete detailed write-ups on flatty engines testing; first unblown dyno results and then blown results. The engines covered are the John Down's 255, the Honest Charlie/Coker 284, the Abbin "Killer" 276 & Bill Boomers 284 (was for sale don't whether Bill sold it yet).
    I particulary liked the heads flow testing information presented in detail for intakes and exhausts for 10 different head sets. Looks like the biggest gains are the result of relieving and porting.
    Jim
  21. Looks great with the heads and intake painted to match.
  22. aldixie
    aldixie
    Very nice. How much did it cost you to get to the short block stage? I have a 59 block that I want to build up.
  23. 40FORDPU
    40FORDPU
    Thank you. $3,000.00, the machine shop work was $1200.00, internal parts were $1800.00.
