Technical Ford FLATHEAD Coils === Good = Bad = Paperweights
Discussion in 'Traditional Hot Rods' started by The37Kid, Sep 16, 2025.
  1. The37Kid
    The37Kid
    Do Ford Flathead COILS have any value? Can you look at one and tell if it is good or bad? Can they be rebuilt, do they have value as cores? Will have some at Hershey.
    51 mercules likes this.
  2. banjorear
    banjorear
    Yes, they can be rebuilt by Skip Haney (I'm ***uming others) in either 6V or 12V. As far as value, it all depends which coil you have, but they are all considered cores at this point. Common ones, not worth more than $5-10 bucks if all the nuts are present. Some of early ones are rarer and worth a little more.
    Jeff34 and warbird1 like this.
  3. The37Kid
    The37Kid
    Thank you! Every dollar helps, I'll bring along the ones I have.
  4. Mac VP
    Mac VP
    Check out the upper portion of the coil…..the domed part. If you see any cracks whatsoever, that particular coil is toast and has no core value. Sometimes the cracks are very hard to see and won’t be apparent until the coil has been well cleaned. The inner guts are always removed and discarded as part of the rebuild process so don’t worry about what is inside. Coil cores that (at least appear to be okay, generally only bring between $5 and $10 value to a rebuilder in my experience.
    Toms Dogs likes this.
  5. alchemy
    alchemy
    Unless it’s a Lincoln, then it’s worth keeping even if it’s got a crack. Lincolns are unusual with their dual humps up top.
