Ford Flathead engine stand adapters
Discussion in 'The Hokey Ass Message Board' started by Nevala, Jul 3, 2013.
  1. Flathead Jack's welded adapter
    2 vote(s)
    100.0%
  2. Red's Headers stud mounted adapter
    0 vote(s)
    0.0%
  1. Nevala
    Nevala
    I need to bite the bullet and pick up an engine stand adapter for 59ab blocks. The style that I know I need is the exhaust manifold type, and there are two options that I can see:
    Flathead Jack's has one that slips through the upright on the stand and is welded like so:
    Red's Headers has a mount that appears to use studs through the plate that already exists on the engine stand:
    Help me decide which one would be best?
  2. Mean Lean
    Mean Lean
    Just build your own, worked for me.
  3. Uncle Bob
    Uncle Bob
    from Salado, Tx
  4. I produced a run of them and had some limited interest. Not enough to move forward, easy to make yourself.
  5. 40FordGuy
    40FordGuy
    Either of those is a good item, or as said above, weld up your own.
    4TTRUK
  6. I got one from Stumpys fab works, he seemed to have the best price also.
      385.3 KB
  7. tjm73
    tjm73
    I have CAD drawings for the flanges from back when I was in college. I need to have a friend make one for me on his plasma CNC table.
    But if you have a manifold it'd be supper easy to make one. A suitably sized rectangle with the bolt holes drilled in the right spots and a correct diameter heavy wall tube cut on a 45 and welded to the plate and you're good to go.
  8. tjm73
    tjm73
  9. Torchie
    Torchie
    Mine came from Stumpy's as well.
    Great price and quick service.
  10. deucemac
    deucemac
    I built mine and it is very close in looks to this one. It cost me $11 in steel bought from the local steel supply using cast off material from their remnant pile. A little time with a drill, chop saw ans welder and you have your adapter
  11. That's what I thought,
    Flathead Jack's $108.00
    Red's Headers $99.00
    Stumpy's fab $64.00
  12. roseville carl
    roseville carl
    built mine years ago.....
    Atwater Mike likes this.
