FORD FLATHEAD GURU's: Unusual flathead stuff
Discussion in 'The Hokey Ass Message Board' started by Straightpipes, Aug 13, 2009.
  1. Straightpipes
    Straightpipes
    Here's one for you guys. Check out this manifold. :eek:
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Looks like it may be part of a KRW valve adjustment setup. KRW made towers which raised an intake manifold about 10" so the valves could be adjusted while the engine was running. That red paint showing through the 1-bbl manifold coat of many colors is very KRW Red looking.
  3. the-rodster
    the-rodster
    Those outside carb mounts have to be added.... right ?
    Rich
  4. Dale Fairfax
    Dale Fairfax
    Most likely for an old Smiths air compressor conversion on the Ford engine: 4 cylinders running; 4 cylinders pumping air.
  5. blown49
    blown49
    How would you adjust the valves on a flathead with it running?????
  6. Bruce Lancaster
    Bruce Lancaster
    You cannot on a stocker; the KRW kit was a set of risers about a foot high (I have a set of those somewhere) and a little gas can that attached to the carb...dealer was supposed to cut away ends of a s**** Detroit Lubricator type manifold, mount it on the risers, and run the engine while looking for souces of noise or whatever. Probably too complicated and messy to be of much use.
    Pretty certainly a compressor manifold...I think there is a picture trackable on Google Patent database of both B and V8 compressor heads and manifolds.
  7. Straightpipes
    Straightpipes
    This is from a Schramm air compressor called a "Fordair 60" . Runs with 4 cylinders and pumps with the other 4. It puts out 60 CFM at 100PSI. Probably enough to run a couple of jackhammers.
  8. BlueOvalCertified
    BlueOvalCertified
    from Minnesota
  9. Pete1
    Pete1
    from Wa.
    The very first flathead V8's that came out in 1932 had a single hole carb on them.
  10. Elrod
    Elrod
    I called air compressor also.
  11. awelker
    awelker
    So have you got that thing going yet, or still cleaning it up?
  12. pasadenahotrod
    pasadenahotrod
    from Texas
    The Detroit Lubricator 1bbl carb was used in 1932 and 1933. 34 was the first use of the 2bbl carb.
  13. Straightpipes
    Straightpipes
    Had a stuck valve so I pulled the manifold and freed it up so now it turns OK, good compression etc so it's ready to roll. Thanks for the tech manual. Startup coming soon. Hows the bellytanker coming? How about an update!!
  14. fuchster
    fuchster
    from San Diego
    Schramm Fordair 60 it is. Do you have any parts for such a beast? I need parts for one that I am restoring.
