Ford Flathead Spark Plugs ?
Discussion in 'The Hokey Ass Message Board' started by Frenchy32, Apr 22, 2010.
  1. Frenchy32
    Frenchy32
    from arizona
    Which spark plugs is everyone using on their Ford flathead V8 ( Champion H10 / H10 C or which other plugs are you using or recommend using ). And what is the gap that you are setting them at.
    Thanks
    Frenchy
  2. chopperbilly
    chopperbilly
    champions got a bad rep so i run NGK or motorcraft. I saw info about that on here. do search you should find good info.
  3. cuznbrucie
    cuznbrucie
    NGK B6L's or B4L's if you need a little hotter plug........I swear by them and you know you can trust me!
    CB
    oldbanger71 likes this.
  4. thunderbirdesq
    thunderbirdesq
    I've got H10C's in mine, they seem to work fine but I've only got about 75 miles on the car.:rolleyes: Running an old Mallory Dual point and they're gapped at .030". What's wrong with the Champions?
  5. Flat Ernie
    Flat Ernie
    Tech Editor
    B6L or B4L NGK
    216 Autolite
    H10C Champion
    Careful with the Champions in aluminum - their threads don't seem to be cut as well as they used to be (cut vs rolled?). Some folks have better luck with a particular brand - I've run all three in various engines - some engines like one over the other, and other engines don't seem to care at all.
  6. Fairlane
    Fairlane
    from Australia
    Just got my flat motor off the dyno. The tuner sent me off to get NGK plugs as he didn't like the Champions that were in it. Personally I dont think there was a difference, but it sure runs sweet with NGKs in there.
  7. tbone1951
    tbone1951
    from COLORADO
    NGK work the best for me
  8. SAFU
    SAFU
    from Arizona
    Japanese spark plugs in a Ford flatty? :eek:
    Dudes, that can't be old school !!!!!!!!!!!!!!! Very uncool. :p
    Put a little anti-seize on the Champion threads, and they should work just fine. :cool:
    SAFU
    buelligan likes this.
  9. 19Fordy
    19Fordy
    Are Champions still made in the USA?
  10. SAFU
    SAFU
    from Arizona
    Oh lordy, please tell me they are. Otherwise I won't be able to sleep tonight. :eek:
  11. j ripper
    j ripper
    from napa ca.
    i use the ngk b6L. could not find them around here recently, so i went back to the trusty autolite 216.
  12. Butch11443
    Butch11443
    I run 437 Autolites in my Offy heads. Have longer thread for the thicker heads.
    Work fine.
    Butch
  13. dirthawker1313
    dirthawker1313
    Autolite 216 for me..
  14. mtflat
    mtflat
    Only Autolite 216's here.... in Ford stock EAB heads. Haven't tried the NKG's
    I've never been able to run Champions in a Ford without it spitting and sputtering.
  15. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I had Champion H10's in and now I am running NGK BL6s. Seem to run great!
  16. Thanks to everyone on this subject great help Jeffrey James you are now using NGK B6L I will try them on my V12 Lincoln and see if I see the difference.
    Thanks again everybody
    Frenchy
  17. Frenchy32
    Frenchy32
    from arizona
    I have called a few stores today including Napa and no one carries the NGK B4L's or NGK B6L's how about the Autolite 216 are they a hotter plug.
    Thanks
    Frenchy
  18. 2002p51
    2002p51
    I run the Autolite 216s in Edelbrock aluminum heads with a Pertronix in the distributor. Absolutely no issues. They've been in there so long, I've forgotten what they're gapped at!
  19. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Well after a couple weeks of running the BL6's I can tell you that it's running really good right now. I got my plugs from O'Reiley's. They had told me they were not stokcing the champions anymore. I think I might go and pick up 5 sets of the BL6's just to keep around. I really should have an extra set in the car.
  20. Silly question. but can one run the NGK B6L's on a 8BA, still with a 6V system?
  21. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I would imagine so but don't quote me on it. The B6L is a direct replacement for the H10 that Champion provided. I assume that the plug would still work when jumping from a 6 to 12v.
  22. cuznbrucie
    cuznbrucie
    Seems to me that the firing of the plug is more a function of the voltage from your coil, right? My guess would be that 6V vs. a 12V system doesn't make a difference........correction welcome if I am wrong on that.....
    One other thing that I know for sure is that if you find you might want a hotter spark, try a set of NGK B4L's.........I am running a set right now for evaluation.........seems to run quite strong though......
    CB
  23. Frenchy32
    Frenchy32
    from arizona
    What is the "s" at the end of the part # NGK B4L's
    Frenchy
  24. champions will fowl prety easy, never really had problems with autolite or motorcraft
  25. Off topic but Love trailer park boys Bubbles is my favorite
  26. Automotive Stud
    Automotive Stud
    If you mean the stock number it's #3112. My flatty with two carbs and a Max 1 cam really likes the B4L.
  27. Thanks !!
    Frenchy
  28. otis firefly
    otis firefly
    Champions BAD.... Autolite GOOD!
  29. hotrodderhaag
    hotrodderhaag
    I have the same trouble with champions... Spitting and sputtering .. Threaded in some ngk and it ran like a top! Champions used to be a fantastic plug... And as most things with the new day and age they have gone way down hill
