Technical Ford Flathead starter help.
Discussion in 'The Hokey Ass Message Board' started by bkcraun, Jan 23, 2017.
  1. bkcraun
    bkcraun
    Have a 52 Ford Customline with the flathead 8. Have not started. Previous owner says motor started with gas can a year ago. Note: I'm a 6 volt newby. So I charge a 6 volt battery. Install with positive to ground and negative to solenoid (like it was) I now have headlights if I pull the light switch but have nothing if I turn the starter switch. No click or anything. What steps do I take next? Just want to hear it crank at this point.
    Replace starter switch? Replace solenoid?
    Thanks!
  2. alchemy
    alchemy
    Give the top of the solenoid a couple taps with a small wrench, then try again. If nothing, look for loose connections on the power from the solenoid to the starter. Also check connections at the ignition switch and everywhere those wires go on their way to the solenoid.
    You could try jumping over the switch to get some temporary power to the solenoid. This would eliminate the switch from the list of suspects if it makes no change.
    If you can find nothing obvious is loose or broken, I usually start replacing parts with the cheapest. I'd bet you can pick up a solenoid from the tractor supply for $20.
  3. steinauge
    steinauge
    from 1960
    You can just jump the solenoid with a jumper cable too.Go from one large terminal to the other. Is your car an automatic? If so your problem may be the neutral safety switch.
  4. Los_Control
    Los_Control
    from TX
    Think that should be a on off switch with a push ****on starter?
    Maybe the cars were a little fancier and had a starter switch, truck would have a ****on to push after the key was switched on. the ****on on the left side of the dash on this 52
  5. bkcraun
    bkcraun
    This is a car. My photo is of my truck and it does have the starter ****on. C
    Automatic . So jump one terminal to another on the solenoid??
  6. stillrunners
    stillrunners
    from dallas
    yes the hot one to the - S - terminal I believe.....make sure in park ! Just a touch of the wires to see where your at....
  7. BJR
    BJR
    Sometimes the cable connections can be tight, and still have corrosion that doesn't show. Loosen them and sand them so they are shiny and re connect them. I had an OT Chev Pickup that one morning would not start. All the connections were tight and look clean. I removed the cable to the starter which also looked clean. I used some sandpaper and got it shiny, re connected it and it started and was good till I sold it years later.
  8. Saxon
    Saxon
    from MN
    Starters usually never go bad. You could just use jumper cables to test the starter, forget the solenoid now. Ground + to engine / - to starter post. if it doesnt crank then go down the path of bad engine grounds, bad wiring, stuck motor :(, bad starter... etc.
    edit as an after thought ***make sure the car is not in gear when jumping it*** Yikes but common sense.
    you could always remove the starter and do the same, just put a couple nuts on the end of the two long bolts first.
    starter grounds to engine, amazing how a little paint f's the start up.
  9. farmalldan
    farmalldan
    from Duncan, OK
    Fords before 1958 only start in neutral. Are you trying to start it in park?
  10. Saxon
    Saxon
    from MN
    You sure about this...??? :)
  11. jimmy six
    jimmy six
    100% neutral starts for early automatic Fords. Sticks no any gear and no clutch switch.. Good luck..
  12. bkcraun
    bkcraun
    Seriously?? I had no idea!! Will let you all know if that works this week-end.
