Ford gauges-SBC engine
Discussion in 'The Hokey Ass Message Board' started by djmahle, Sep 23, 2009.
  1. djmahle
    djmahle
    from Minnesota
    I am putting a SBC enigne in my 50 Ford. Yes I know a small block Ford would be better, but I already have the rebuilt Chev engineand trans from another project. Would like to use the existing gauges. I know that I have to reduce the voltage but was wondereing if anybody knows what senders will work for the Ford gauges that also fit the 350 Chev engine. Thanks for your help.
  2. roughidle
    roughidle
    from iowa
    You'll have to find adapters to go between the senders and the engine.
  3. DonMan
    DonMan
    Like Roughidle said, you need to use senders for a `50 Ford and use brass adapters to fit them to your Chevy engine. Pretty simple.
    The oil psi sender is 1/8 NPT and is located just behind the distributor.
    You can install the coolant temp sender in the intake coolant passage or in the head, between the spark plugs - should be a 1/2 NPT there.
    OR ------
    Mount some vintage "mechanical" gauges under the dash.
  4. marks914
    marks914
    Alliance Vendor
    The gauges do not care what engine it is, it only cares what the sender is saying. Most GM and ford senders are 1/8, 1/4 and 3/8 so it should be plug-and play
    No voltage reduction required on a mechanical gauge either.
    Mark
  5. djmahle
    djmahle
    from Minnesota
    Thanks for the help.
