Ford Guys: What are these?
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Mar 27, 2011.
  1. Bigcheese327
    Bigcheese327
    I'm clearing out a bunch of miscellaneous parts I'll probably never use, and a**** a bunch of stuff marked for late Falcons, Mavericks, and Granadas, I found these:
    Are they speedometer gears? I'm wondering if they should go in the keep pile, the p*** on pile, or the junk pile.
    Thanks,
    Dave
  2. look like speedometer gears to me, just my guess.
  3. SlmLrd
    SlmLrd
    from DAGO
    Look like speedo gears to me :)
  4. Cshabang
    Cshabang
    yep, speedo gears...
  5. Bigcheese327
    Bigcheese327
    Okay, I'll keep 'em then. Thanks!
    I ***ume they're color coded. Can anyone tell me which colors mean what?
    -Dave
  6. Gasserfreak
    Gasserfreak
    from Yuma, AZ
    Should be different teeth count for calibrating your speedo after tire size or rear gear change.
    Drew
  7. hotroddon
    hotroddon
    If you don't want them , I could use them.
  8. 48MOPARCPE
    48MOPARCPE
    If your worrking on a Ford with a mechanical driven speedo,these gears will make your day. The tooth count on the gear changes MPH on the speedo faster or slower.
    Keep them.
  9. Bigcheese327
    Bigcheese327
    I think I'm going to see if I can dial-in the speedo on my Falcon first; but I'll happily send you the leftovers.
    -Dave
  10. hotroddon
    hotroddon
    Cool - thanks (could use with my Falcon with T5 and 4.10 gears)
  11. voodoo1
    voodoo1
    The green one is for a reverse rotation....................
  12. Bigcheese327
    Bigcheese327
    Seriously? I thought it was just a 17-tooth gear for a manual trans.
    -Dave
  13. Mike Miller
    Mike Miller
    Some transmissions had the gear on the right side instead of the left.
    <!-- / message -->
  14. KEITHMAN
    KEITHMAN
    The tooth count should be on the gear somewhere. IIRC it's on the end of little shaft. You should keep 'em!!!
  15. terry48435
    terry48435
    Speedo gears for sure.Had them in my C4. I think they work in other Ford transmissions also.
  16. Left Turn
    Left Turn
    from Omaha, NE
    speedo gears! keep 'em! (we've got a shoebox full on the ****** bench at work, nice to have around)
  17. Ole don
    Ole don
    Since a new one is about twenty or more bucks, and they look to be good, - - - - -
  18. Engine man
    Engine man
    from Wisconsin
    As can be seen by the angle of the teeth, these are all for the same rotation.
    With Ford, it wasn't as easy as changing the gear on the cable. You can change the angle on the gears a little but to get beyond a certain range, you also had to change the output shaft on the transmission. I was working at a Ford dealer in 1979 when one of the salesman sold a customer a vehicle and told him we would install the towing package on it. The trailer hitch, lights, and heavy duty radiator weren't any problem. After the rear end was changed, the speedometer was way off and we couldn't get a gear to get it right. The input shaft would have had to be changed. It was cheaper to have a speedo shop install a gear reduction unit.
  19. boutlaw
    boutlaw
    Check the Mustangs Unlimited catalog, they sell the gears and the color codes are ID'd in their catalog. As mentioned earlier, tire size/gear ratio, as well as which spiral gear is installed in the trans determines speedo accuracy. If I remember correctly, the T-5 only offered about 3-4 gear options. Of course, it took me 4 tries to get the best calibration!
  20. Gasserfreak
    Gasserfreak
    from Yuma, AZ
