Ford hub problem
Discussion in 'The Hokey Ass Message Board' started by tommysrodshop, Aug 19, 2009.
  1. tommysrodshop
    tommysrodshop
    from Texas
    I have a car in my shop that has MT products drum brakes on the front. It has early ford style spindles. I need some hub and drums that have 5 x 4 1/2 bolt pattern that will bolt up. Someone has redrilled these to 5 x 4 3/4 already so they cant be reused. any suggestions ??
  2. Bob Wilson in Flower Mound, TX http://www.wilsonweldingandmachine.com/ offers a hub that is drilled for the 5 x 4.5" bolt pattern. It is intended for use with Buick drums. But I don't see any reason why they would not work with replacement Ford drums (hub outside style). Talk to Bob.
  3. tommysrodshop
    tommysrodshop
    from Texas
    Thanks I'll give him a call
    T.
  4. tommysrodshop
    tommysrodshop
    from Texas
    Wilson only makes hubs for use with Buick drums. Hub problem still going and going !!!!
  5. 325w
    325w
    Tommy, check the bearing numbers to see if there the same as pickup. are car. If the bearing numbers match then try that hub. You can find most of the number here on search I think.
