Ford King Pin question
Discussion in 'The Hokey Ass Message Board' started by Dugg, May 1, 2006.
  1. Dugg
    Dugg
    Can I use '35 Ford King Pins it I cut off the brake-linkage-cup-things at the top of the pins?
  2. Sure you can.....unless you're running mechanical brakes. In that case you will need them..... :)
    Remember....the thrust bearings go on top of the spindle, not between the axle boss and the spindle like on the later versions.
