Hot Rods Ford Logo - DXF??
Discussion in 'The Hokey Ass Message Board' started by HemiRambler, May 24, 2014.
  1. HemiRambler
    HemiRambler
    I am looking to duplicate the Ford Safety Gl*** logo (I doubt it exist - but I dunno) ***uming it does not - does anyone have a DXF of the Ford Script? Or an EASY way to duplicate it?
    To clarify - it's for a 1947 Ford - I ***ume I won't get the entire logo - with the safety gl*** part - but if I can find the 40's script Ford logo - that'd be cool.
    Thanks
  2. HOTRODPRIMER
    HOTRODPRIMER
    This is the only logo I remember. HRP
  3. gimpyshotrods
    gimpyshotrods
    Tread lightly. Ford still holds the rights.
  4. HemiRambler
    HemiRambler
    Why? I'm not selling it? Am I actually bending any laws by duplicating it for my own purposes?
  5. HemiRambler
    HemiRambler
    HotRodPrimer - yes very close. MIne just has "FORD Safety Gl***" no other numbers or letters. Is that SCRIPT available in DXF?
  6. gimpyshotrods
    gimpyshotrods
    Read up on trademark laws. Use is enough to warrant action, even without profit.
    You will likely be fine, but make sure that you are engaging with informed consent, rather than guessing.
  7. gwhite
    gwhite
    SUPER MODERATOR
  8. gimpyshotrods
    gimpyshotrods
  9. HemiRambler
    HemiRambler
    Gimpy , It looks like my only choice will be to cut out that logo and weld it into my new gl***. Can anyone instruct me on the details for welding gl***??? I have a TIG - will that work?
    Seriously though, Gimpy - I do appreciate your comments.
  10. gimpyshotrods
    gimpyshotrods
    Those are gl*** etch stencils. You adhere them to your gl***, in the proper location, paint on the etch compound, wait 30 seconds, clean the etch compound off, and then remove the stencil.
    What you are left with is the logo, etched on your gl***, just like OEM.
  11. gimpyshotrods
    gimpyshotrods
  12. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    What about using some thin shim stock w/ the logo cut out...once you find the correct design to copy.......glued in place and lightly....real lightly...sandblast it ?...I did something similiar that was real small and detailed onto plastic once........I can break gl***.....but not weld it...ha ha ha.......Good luck I know you will come up w/ something....
  13. HemiRambler
    HemiRambler
    OK so I made a pattern and had a buddy cut it out. We used a sticker that was laying around - nothing special - just a "paper" type sticker.
    Since I am NOT a restorer some modifications were in order.
    This was a test run on the wife's q-tip jar - hopefully she's not too mad <big grin>
    I think I like the general proportions, but I am planning on thinning everything except the "FORD" script - that looks right to me.
