Ford Maverick 8" rear install
Discussion in 'The Hokey Ass Message Board' started by nhmikel, Aug 3, 2012.
  1. Oilcan Harry
    Oilcan Harry
    from INDY
    Can't tell ya that but, only V-8 applications had the 5 lug pattern. I had a V-8 72 Grabber I bought new. No 15" wheels were offered and the limited slip differential was available as a dealer installed option.
  2. Deuce Roadster
    Deuce Roadster
    This is incorrect !! :)
    Some of the six cylinder models with the optional 250 ci six cylinder also came with the 5 lug wheel bolt pattern. The Mercury Comet of the same years as a Maverick also had the 5 lug wheel pattern IF they had the 250 ci 6 cylinder engine.
    :D
  3. Oilcan Harry
    Oilcan Harry
    from INDY
  4. nhmikel
    nhmikel
    from NH
    Did not notice a drain plug??
    How do do drain out the nasty oil?
    Do I fill it up with the "vent" tube looking stub?
    Any ideas on which supplier is cost effective with the ebrake
    adapter to fit this rear end?
  5. 26 roadster
    26 roadster
    some 8" housings had drain and fill plugs, some had only drain and the stump had fill plugs. from experience check!! or you end up adding a filler after it is painted!
  6. Hnstray
    Hnstray
    from Quincy, IL
    Draining can be a problem when no lug is provided. Pull the axles, remove the third member....clean everything up....re***emble. If you are ambitious, weld a bung or nut from an old oil pan into the bottom for future draining ease.
    As for filling....there should be a filler plug on the side of the third member casting.
    Ray
  7. bchrismer
    bchrismer
    Hey NHMikel,
    On my '40 Coupe, I had ran a set of Dodge van wheels on the back. They were 15x7, with a 5x4 1/2 bolt circle. I ran a set of JC Whitney baby moons on them. The backspacing was 3 3/4.
  8. Leakie
    Leakie
    What GM car has a 5x4.5 pattern???
  9. 26 roadster
    26 roadster
    front wheel drive cars, my company 99 Lumina can run crown vic wheels, my 03 buick ultra same thing, check them out
    4.53" 115mm
  10. 19Fordy
    19Fordy
  11. nhmikel
    nhmikel
    from NH
    I also used and made this site favorite
  12. gimpyshotrods
    gimpyshotrods
    Yup. Found this out the hard way, when doing a last-minute quick pumpkin swap on my bosses' car for a Ventura run. It got filled through the vent tube, via a pump. Oosp.:eek:
