Ford Mini starters
Discussion in 'The Hokey Ass Message Board' started by Hellfish, Aug 7, 2007.
  1. Hellfish
    Hellfish
  2. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    They're good. Ford has been using them for a while now. Same with GM.
    We have a whole flock of trucks here at work, very few starter problems with GM , Dodge or Ford. All have small starters.
    beats the hell out of spending $200 for a aftermarket one.
  3. Gotgas
    Gotgas
    from DFW USA
    They're good.
    But they wire up COMPLETELY differently than the original starter did.
    Do an internet search, the wiring info for converting from a large to small Ford starter is out there.
  4. jmn444
    jmn444
    I just bought one from dbelectrical on ebay. I called em first to be sure I was getting the right one since my application wasn't listed, a T-5 trans uses the automatic starter apparently...
    anyway, only had it in for a couple weeks but very happy with it so far and they included the extra wire you'll need since the mini starters get wired a bit different than the old style ones. very simple to swap.
    here's what i bought:
    http://cgi.ebay.com/ebaymotors/ws/e...STRK:MEWN:IT&viewitem=&item=130135188247&rd=1
    good luck!
  5. jmn444
    jmn444
    FYI, the wiring change is simply moving the previously keyed power line to the constant power side of the solenoid, then adding the wire they include to the keyed side of your solenoid so that it actuates the onboard solenoid. About as simple as it could get.
  6. AnimalAin
    AnimalAin
    Used a Ford reduction gear starter on my new motor for the roadster. Compact, significantly lighter than the old one, and spins the motor with authority. Local auto electric guy was the vendor; cheaper than some, but probably not the all-time record low price. It did need a little jumper wire to make it work right, but was really no biggee.
  7. tcoupekyle
    tcoupekyle
    We had a really cool mini starter on a late model ford witha 351 it held up a long time about 6-7 yrs
  8. hammrd29
    hammrd29
    mine works great and i think my dad has had one on his car for about 2 years
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    Highly recommend the people at DB electrical,I bought my one wire alternator and mini-starter from them for my 302 SBF in my '54 Ford.I had some questions,they were helpful big time shipping was fast and prices great!:)
  10. 461/2ton
    461/2ton
    I have one on my 292 Y. It works great. No going back to that 25-30 lb piece of lead for me!
