Ford Model "b" banger help
Discussion in 'The Hokey Ass Message Board' started by BrandonF, Mar 16, 2013.
  1. BrandonF
    BrandonF
    The answer was larger jets. I used a .051 and it runs quite well. It has a slight hesitation on take off. I think I'll try a little bigger jet. Thanks to everyone for all the advice.
  2. Bruce Lancaster
    Bruce Lancaster
    Those should be close to right. Don't mess with them for immediate off-idle...they likely aren't even feeding at low speed. Readjust idle, see what happens. If no results there, check out advance...it should be moving right off idle. Next check out the feed p***ages for the idle and off-idle.
    Mains don't do much until you are up a bit in revs.
    -Brent- likes this.
