Ford Motor Mount ID Help???
Discussion in 'The Hokey Ass Message Board' started by alteredpilot, Sep 26, 2011.
  1. these came off of the 302 that was mounted in my 54 ford. i dont know what mods were made prior to my getting it. any help?
  2. lukey
    lukey
    Order mounts for a 64 galaxie with a 289. The 302 sits in stock 223 frame mounts with no mods. Thats what those look like
    -LUKEY-
  3. any other vehicle that shares that mount for the sake of searching?
  4. lukey
    lukey
    Mid 60s fairlanes, 68-69 torino, early small block mustangs, and many more
    -LUKEY-
  5. very good. thanks.
  6. sdg
    sdg
    It's hard to judge the offset of the stud with a photo, but it looks like the standard 302/351 engine mount that ford used for years.
    If it's going in a high-horse application (or you never want to have to replace it again, use this replacement set from Autofab. I have them on my Bronco and love them... easy to install and super strong.
  7. 56don
    56don
    F100 truck mounts if I am remembering correctly.
  8. hotroddon
    hotroddon
    Really common - there are two basic types of small block Ford mounts, those like you posted and ones that use the Crossbolt instead of a stud like those.
    Here's a few that used that style that you want
    Bronco 289 cu.in. (1966-68)
    Bronco 302 cu.in. (1968-86)
    Bronco 351W (1983-86)
    Pickup 255 cu.in. (1981-82) 2WD
    Pickup 302 cu.in. (1969-86) 2WD 1/2, 3/4 Ton
    Pickup 302 cu.in. (1980-86) 2WD 1 Ton
    Pickup 351W (1980-86) 2 & 4WD - 1/2, 3/4, 1 Ton
    E Series Van 302 cu.in. (1968-74)
    Don't get the really early Mustang/Falcon stud type, they may not interchange with yours.
  9. 62rebel
    62rebel
    i bought truck mounts to use in case i had to replace my '59 FE with a smallblock. uh.... and i still got the damn things. no '59, no smallblock, just a new pair of freaking mounts. too stingy to throw them out.
  10. chopper cliff
    chopper cliff
    from lodi ca
    My 65 Mustang 289, used this style of mount, still use on my Ford conversions
  11. 56don
    56don
    Go ahead and chunk them in a trash can. The next day you will need them. Thats why I don't get rid of anything....
