Technical Ford motor mounts re: 351 c
Discussion in 'The Hokey Ass Message Board' started by FoxSpeed, Apr 5, 2014.
  1. FoxSpeed
    FoxSpeed
    from NorCal
    I have just purchased a 56 f100 that has a 351 cleveland engine. The engine is toast, I am wondering which engines, (ford small block), would use the 351c existing motor mounts.
    Primarily I would like to use a 302 or 351 windsor.
    Thanks
  2. Relic Stew
    Relic Stew
    from Wisconsin
    351C uses the same mounts, flywheel, and bell housing as the 302 and 351W, so it's a direct swap.
    If it's actually a 351M/400, which look similar, the mounts are unique and it has the 429/460 bell housing pattern.
  3. okiewelder
    okiewelder
    from central Ok
    I think the mounts are the same for the cleveland and the Windsor engine family.
    Does your truck presently have the universal type mount in it that is kinda like a short tube that is kinda like a cradle?
    What transmission are you going to run?
  4. 58custom
    58custom
    Relic Stew is correct. Please post a picture of the engine front showing the head & distributor area and we will be able to tell you if it is the low-deck 351C or the tall-deck 351M/400.
  5. FoxSpeed
    FoxSpeed
    from NorCal
    OK, I will post pics later. Thanks
  6. Relic Stew
    Relic Stew
    from Wisconsin
    The easiest identifier is that the thermostat and intake seal area around the distributor are higher on the 351M/400. Also the ridge to the drivers side of the distributor.
