1952-59 Ford ford o matic question
Discussion in 'Off Topic Hot Rods & Customs' started by streetlordz, Aug 12, 2012.
  1. streetlordz
    streetlordz
    Hi, My name is Vinny I am from Pittsburgh area. Recently had a problem which caused a fire. Fortunately i caught it in time. My "two speed" Fordomatic transmission pushed the dipstick out of the tube and puked fluid in large amounts all over my exhaust. I was climbing a gradual grade and noticed a slight loss of power. I down shifted and all hell broke loose. I am new to this automatic and was wondering if anyone could help. Its in a 54 Merc with a 292 Y-block. Are the mercomatic and fordomatic the same ??
  2. streetlordz
    streetlordz
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Probably the best site for info on a Ford-O-Matic is here http://www.network54.com/Forum/260730/ let us know what you find out,sadly since the Ford-O-Matic has been out of production for 50+ years so are a lot of the folks that worked on them.
  4. hey vinny if you want to throw a manual back in there i have one from my customline..engine as well..and i also forgot to call you back about playing the show, cause i was in jersey on vacation.. august and most of september are booked up..
    -Johnny
  5. streetlordz
    streetlordz
    Hey Johnny, Thats cool. We got good 'ol Mermphis Mike and the boys. Im gonna try to salvage this transmission if I can. The wife likes the automatic. Thanks though.
  6. no problem. if you do need engine parts let me know. cause i have a 55 customline that i'm parting out and i'm not using the engine or transmission
  7. paleot
    paleot
    from louisiana
    Vinny I am not experienced on the fordomatic, although i have one I just pulled from my 53. I had a ford p/u 460/c6 when I pulled hard it wouldpuke oil and vapor to the point of looking like it was on fire. My problem was the vent on the trans was plugged causing it to build pressure! I know the f/m has a vent you might check it.
    Luck Tony
  8. streetlordz
    streetlordz
    The vent wasnt plugged but it seemed as though the cap on the vent was worn and would actually seal the vent when pressure was applied. I took the cap off and replaced it with a hose which dumps over the frame instead of on the exhaust. I dropped the pan and cleaned the filter and what little sludge was in the pan. Checked the air intake screen and put some type F in it. Everything seems to be good so far. Thanks for the help guys.
