Ford part #'s? (rear main bearings)
Discussion in 'The Hokey Ass Message Board' started by 50 Flord, Apr 6, 2005.
  1. 50 Flord
    50 Flord
    from kansas
    I have some new (old stock) Ford rear main crankshaft bearings. I need help researching some part #'s. I did some lookin' but had no luck. Here are the #'s. 1. 18-6331-C 2. 81A 6331-F2 3. 52-6331-G 4. 1GA-6337-A 5. 68-6331-C. Thanks for any info or tips that may lead to the year and/or model of engine these bearings go to.
  2. Bruce Lancaster
    Bruce Lancaster
    18 prefix: .010 under, for use with early '32-36 crank in late 1936-38 type block--this one should be real thick!
    81A--F '39-48 V8, 010. Maybe the 2 means both halves are in box?
    52-60HP, '37-9, .010
    1GA 6337-A6 cyl '41-7, lower rear main, standard
    68 -C, late '36, '37-8 21 stud, 010
  3. 50 Flord
    50 Flord
    from kansas
    Thanks for the reply. Is this information in a book somewhere or are you really good with Ford part #'s? I have alot of parts like this and would like to know what motors they are for. Thanks again, 50 Flord.
  4. Bruce Lancaster
    Bruce Lancaster
    What you need is the "Green Bible", the '28-48 Ford parts compilation, and perhaps the '49-59 one too if you have later stuff. Most parts can be guessed at fairly well from the prefix #, which gives information on year of introduction and engine or car type. Early Flathead bearings are getting scarce.
