Ford Pinto engine
Discussion in 'The Hokey Ass Message Board' started by sgtlethargic, May 19, 2011.
  1. hotroddon
    hotroddon
    The 4.0 is a Cologne V6 and is completely different from that pig known as the 3.0 Vulcan V6. Even though the 4.0 is only used in American market vehicles, it was still made in Cologne, as is the newer SOHC 4.0 V6. The 3.0 Vulcan is a gutless wonder that gets lousy mileage.
    As for the Pinto 4 bangers, the 2.0 cars went pretty well, they made just over 100 HP.. The 2.3 came out in 74 and was so straddled with smog **** it only made 88 HP (still more than a Flat Head!) and 118 ft lbs TQ, and the cars got heavier with all the 5mph bumpers and other safety mandates. They did make turbo versions that made 190 HP and then SVO Mustang version made 205 HP!
  2. d2_willys
    d2_willys
    from Kansas
    Ha Ha, that Vulcan can probably kick the **** out of most 4 litre colognes. I know mine eats 4.3 v-6 Chevy S-10's for breakfast, lunch, and dinner. MPG is 22mpg! You must be thinking of some other POS. My truck has over 100K with 5 speed automatic, and believe me I bought it for the responsive powertrain, so either mine is one of the good ones, or the ones you know of are just plain shot.
    Most of those Pinnos had automatics that were just plain dead with any engine. Now a 77 Pinno wagon and 5 speed stick would go 60 in first gear alone, had some really tall gears, that made it a bit sensative starting out in 1st.
  3. JEM
    JEM
    Ford had a busload of different V6s.
    The 'Cologne' motors started off as a 1.5-1.7L V4 (German Taunus, Saab 95/96, lots of industrial applications like forklifts and water pumps) and a 2.0 / 2.3L V6 in the mid '60s. Then 2.6, and 2.8. These motors had somewhat odd heads with siamesed ports (3-into-2 on the V6) and even the V6s have the wide asymmetrical pan rail where the V4s had a balance shaft. Then a 2.9 with 3-port heads, a big-time punch-out to 4.0 for the US trucks with new heads and better valvetrain, a Euro-only 2.9 w/Cosworth DOHC heads (a very popular swap engine in the UK but they make no power stock), and the SOHC 4.0 with the funky both-ends-of-the-block cam drive for the trucks and Mustang.
    The 'Es***' V4/V6 was a UK-built design done in parallel with the 'Cologne'. Nothing special. Supposedly quite heavy.
    The 'Vulcan' was Ford's version of the Chevy 60-degree V6, I guess Ford decided the Cologne V6 wasn't adaptable enough to FWD or something.
    The '89-95 Taurus SHO V6 was designed and built by Yamaha, it shared lots of dimensions (bore centers, bearing sizes, etc.) with the Vulcan but didn't share a single nut, bolt, or bearing shell with it.
    These were all 60-degree engines.
    Then you have the 3.8/4.2 90-degree US motor cribbed off the Buick 3.8 sometimes called 'Es***' but nothing in common with the UK one and usually cursed at for blown head gaskets, and the 2.5/3.0 'Duratec' 60-degree V6s, and the recent 3.5/3.7 Duratec V6 which shares nothing with the 2.5/3.0.
    And I'm probably still missing a couple (the Mazda V6 in the Probe comes to mind...)
    Was the SOHC 4.0 used in some Land Rover models?
    The 2.0 was a good motor. The whole period from '73 up to probably '82 is best forgotten as far as Detroit motors are concerned.
    The first turbo 2.3 was a 127HP carbureted thing in the late '70s, remember this was a point where 302s were rated 120ish net and barely making that. The first EFI 2.3 was around '82 in the Thunderbird, 145HP. Then 175 in the Merkur XR4ti and SVO Mustang and 205 in the last SVOs.
  4. JEM
    JEM
    The Brits more often than not run them carbed in kit cars e.g. Westfields, but I'm not sure about the conversion details.
  5. hotroddon
    hotroddon
    I have owned 3 Rangers with 4.0 and one with the 4.0 SOHC. I also owned one with the 3.0. (as well as a 2.9 and 2 2.3 4 bangers)
    I bought the 3.0 truck new with a 5 speed and it was such a DOG that I took it back 2 weeks later and traded it for a 4.0 5 speed with 3.73 gears. That thing HAULED *** compared to the 3.0
    When I bought my last one, a 2008, I drove them back to back and there was no comparison. The 3.0 made 148 HP and 180 TQ (Hell the 2.3 4 cyl made 143 HP and 154 TQ) and the 4.0 made 207 HP and 238 TQ - I bought the 4.0 with 5 speed auto
    They dropped the 3.0 after 2008 due to lack luster sales. I was told by more than a few Ford folks that the 3.0 was only offered because they were essentially excess capacity Taurus motors that they had to put somewhere!
  6. modified
    modified
    I have a stock '72 2.0 Pinto in my modified with a C4.
    Runs great. Parts a getting hard to come by, a better choice
    now would be 2.3. Esslinger has a ton of performance parts.
  7. ibarodder
    ibarodder
    I bought a new pinto in 73 that had the 1600 cc overhead valve cast iron engine. It was a good engine without any problems.
  8. 64 Wildcat
    64 Wildcat
    The one in my '84 Ford Sierra has a front sump, and I'd guess that the Capri might be the same.
    They're robust little engines and apparently the later '205' blocks can be punched out to 2.4 litres using Cologne 2.8 V6 slugs and a heck of a lot of decking of the block. That's probably the way we'll go with the little wagon and with a mild street cam should put out some useable power.
  9. I ran oval track with a pinto mini stock race car about 20 years ago. 2.0 motor, block milled, head shaved, cammed, amazingly quick. sent the stock cam out to be reground. Blew a motor when we lightened the rods and didn't shot peen them. 5 quarts of oil coming out of turn 4 spilled on the asphalt track. Caused quite a pileup :D
  10. B Blue
    B Blue
    The common configuration for the "Pinto" 2.0 is front sump. Some were rear sump, I think they were on the Capri.
    The 1600 Kent is a nice little engine, light and tough with good power, but might come up a little short on oomph in a heavy project. The 2.0 is a good engine, but heavy. Its short coming is small cam bearings. Add about 50 pounds for the 2.3. Word is the Ford engineers were in a time crunch to get it on the market and had neither the time to engineer the engine on paper nor the computer power to do it the modern way. So they erred on the side of side strength and weight.
    The Zetec is a good engine but no way your going to run a carb and dizzy without spending big bucks and or hours.
    An engine worth investigating is the Tempo 2.3. It is not related to any Ford 4 banger, but was derived from the 200 inch six. Don't know about all model years, but the earlier ones used dizzys and either a carb or TBI. They have the same bell pattern as the Pinto 2.0, which means a Ranger 3.0 ****** will work, or any 2.3 "Lima" ****** with some modification. They were all fwd, so motor mounts might be a challenge.
    Bill
  11. storm king
    storm king
    I love Ford's little 2.0 motor, stout, lotsa performance goodies for it, long history (relatively speaking). I also like Mopar's 2.2, although it has great performance, goodies are hard to come by. It was a great motor, short production life unfortunately.
  12. Kenneth S
    Kenneth S
    The 2.0 EAO engine had a front sump in the Pinto, a rear sump in the Capri.
  13. 302aod
    302aod
    from Pelham,Tn.
    I worked at a chevy dealership during the block problems. We replaced many blocks under warrenty. Replaced blocks and pistons. The word going around then was that the Vega was the 1st car GM built that started rusting before it left the factory. The 1.6 and 2.0 were both good engines. The 2.0 was fast and durable, we had a new Pinto racecar at the Ford dealership I went to. Holley, headers and a cam.The 2.0s were popular with old Jeep owners. The 2.3 Lima is a good engine too.
  14. mac miller
    mac miller
    from INDY
    Here is my 2300 Ford Lima in my Miller race car replica. Actually, this engine and C3 transmission came out of a Mustang but it is the same engine the Pintos used. I made the OFFY exhaust header and the intake manifold for a single side draft Weber carb.
    Also, check out my 2 litre AlfaRomeo engine in my Watson roadster. OFFY exhaust header and two dual throat side draft Weber carbs. Transmission is an Alfa 5 spd manual.
    mac miller in INDY
  15. Sumfuncomet
    Sumfuncomet
    The 2.0 were the best, had one years ago in a sandrail with a VW trans and an adaptor. You should google Racer Walsh for parts, speedway has a ton of parts also, they are very popular around here with the starter cl*** on the dirt modifieds, not super expensive to build.
  16. falconsprint63
    falconsprint63
    from Mayberry
    I hate to be "that guy," but how did a pinto engine thread make it this long? my dad swears by the 2300's and I spent my childhood in a dookie brown pinto wagon but.......
  17. I know nothing about the small Ford engines (I always use the Chevy II /Mercruiser type) but I think I remember hearing that one was preferred due to the location of the starter and steering issues.
    Charlie Stephens
  18. racer76
    racer76
    I raced a 2000cc pinto motor against 2300cc pinto motors and it kicked their ****s on 1/3 mile or shorter tracks....the 2300 had more top end on the 1/2 mile tracks.....the 2000 would put out 279 hp....not bad for a motor that.... Started out with 104hp .....cranked that thing at 9700 rpm all day long
  19. Don't hold me to it but I believe the smaller displacement engines are push rod motors. I have owned a couple of 2.0s they are a real stout little engine.
  20. 57Custom300
    57Custom300
    from Arizona
    The 1.6 (English) & the 2.0 (German) were both good engines. 2.3, not so much. I recall being impressed on the size of the rod bearings on the 1.6.
    The 2.0 was an OHC w/mechanical followers to adjust the valve clearance. Only drawback was the oil line on the head that would plug up & wipe the cam out. Replaced more than my share of 2.0 cam under warranty. The 2.3 had more than its share of problems. Anyone remember the piston recall in the 70's? Helped finance my divorce back then.
  21. aaggie
    aaggie
    Plenty of speed parts available from places like Smiley's and Speedway, they use the engines in circle track racers.
