Ford Pinto rear diff worth anything??
Discussion in 'The Hokey Ass Message Board' started by 1950ChevySuburban, Dec 6, 2008.
  1. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    wondering if it goes in the s**** pile or not.
    1972 4-lug Pinto, 57" wide from axle flange surface.
    Open drive (not posi).
    Small, obviously not for V8 use, right?
    Cleaning out the yard, thats all.
    Thanks!
  2. brandon
    brandon
    cover type or stump type...? didn't some come with 8" rears...? brandon:D
  3. Andy
    Andy
    Yep! It is an 8" I found one with 4.11 gears. Slip in Maverick axles and go
  4. Kenneth S
    Kenneth S
    More than likely it's the very weak 6 3/4" rearend (8 bolt rear cover, shaped like a stop sign), it's not worth anything.
  5. Duration
    Duration
    from Wayne, MI
    if it has a bolt on rear cover its the weak one. if it is an integral type it might be worth a dollar or two
  6. 55 dude
    55 dude
    rotating mailbox post!:D
  7. fordcragar
    fordcragar
    from Yakima WA.
    I don't think that the 8" rear end was available until 1974 (Pinto/Mustang II), so if it is in a 1972 it's probably s****.
  8. k9racer
    k9racer
    the local circle track guys will buy it. Lots of pinto mini stocks out their.
  9. FrankBoss
    FrankBoss
    sell it. to a Pinto guy..www.fordpinto.com
    if it was out of a wagon the brake drums are wider and a little harder to find in the parts stores.
    FrankBoss
