Ford Pullys ????? Dreadman?
Discussion in 'The Hokey Ass Message Board' started by HotRodHon, Jul 10, 2007.
  1. HotRodHon
    HotRodHon
    Ok, against all of my pleading, my buddy is putting a Ford motor in his T roadster. :eek: Now I'm a Chevy guy, so I'm not a lot of help to him when it comes to what to get pulleys off of that will fit his motor.
    He's running an 87' 302. Anything special about the pulleys for the crank and water pump, or are Ford's as universal as Chevy's.
    Thanks in advance for the help.
    Craig :cool:
  2. s.r.i.
    s.r.i.
    from Hell
    Nope, they are nowhere near as "universal". Ford LOVED changing timing covers and water pumps.
  3. HotRodHon
    HotRodHon
  4. HOTRODPRIMER
    HOTRODPRIMER
  5. HotRodHon
    HotRodHon
  6. What, I'm the authority on SBF's now? I'm not at all.
    I'm fortunate that a own a whole bunch of pulleys and I can just find the one I need, but I could not tell you for what year, they were made for.
    But I recommend calling Owens Salvage (Alliance Vendor) they know their stuff and probably have what you need and ship it to you with lightning speed.
    BTW: In the end it's all worth it, Fords belong in Fords. But I would put a Ford motor in a Chevy, "if" I had one.
  7. HotRodHon
    HotRodHon
    you betcha :p
    doesn't is say fomoco mofo in your sig?;)
    Thanks for the tip:D
  8. junkyardjeff
    junkyardjeff
    Since its a 87 motor just find the pulleys and alt brackets off a 80s crown vic and you can just run the alternator with that set up,the alternator bracket is a bulky aluminum piece but it can be trimmed some to look better. The older non powersteering pulleys from the 70s would be better but they are harder to find,they are usually in trucks since p/s was optional and most cars came with it. Pulleys from a 351-C will work too and if a truck with a 351-M/400 is found without p/s those pulleys might work too. Jeff
  9. Royalshifter
    Royalshifter
    Moderator
    Dreadman to now "SBFman"
  10. Oh please, I'm more of a BBF guy and a wanna be Flathead guy.
  11. FoMoCo_MoFo
    FoMoCo_MoFo
    BIG BLOCK FORD MOTHER****ER!
    trust me Chris, Ballbraker has the same issues when putting the SBF into his `48 that's why it isnt done yet.
  12. It's not really that big of a deal, just gotta do some research. Owens Salvage to the rescue.
  13. greezy28
    greezy28
    fords **** when your missing something from the front. I bought a truck that had a 460 and didnt have brackets or anything and it was a huge pain in the *** trying to chase the stuff down. I would say if you cant find pulleys get a junk motor you can steal everything from.
  14. tjm73
    tjm73
    If that '87 5.0 is out of a Mustang or an F150 it has a reverse rotation water pump. If it's out of a Crown or Lincoln or Mercury Grand Marquis it should have a standard rotation water pump. Easy to switch to which ever one you need.
    If he wants v-belts he can do that and if he want's a serpentine belt he can do that.
    What can you tell us about it's doner vehicle? What was it? Is he running any accesories other than an alternator?
  15. HotRodHon
    HotRodHon
    There was no doner car. :eek:
    He picked up an 87 short block and put on some windsor heads?
    I'll call Owens and see w***upp.
    Thanks all for the help.
    Craig :cool:
  16. tjm73
    tjm73
    well that makes it all the more importent to know what he is workign with. Let us know what he has and I'm sure we can help fill in the blanks.
