Ford Ranger Frame Use?
Discussion in 'The Hokey Ass Message Board' started by Txkahuna, Mar 13, 2013.
  1. Txkahuna
    Txkahuna
    from Texas
    Has anyone used a 80's-90's Ford Ranger frame for an early
    Ford F1 swap? If so pics please....
    KJ
    Little Wing likes this.
  2. FrozenMerc
    FrozenMerc
    Nope, the F1 frame works just fine....
  3. Kenneth S
    Kenneth S
    The Ford Ranger frame with all it's weired shapes is just too much trouble for a swap of any kind, it's easier to stick with the F1 frame.
  4. dynaflash
    dynaflash
    from South
    I have one under my Ranger
  5. HOTRODPRIMER
    HOTRODPRIMER
  6. Kenneth S
    Kenneth S
    Wow, so do I :D
  7. Johnny Wishbone
    Johnny Wishbone
    That is a f&%king mess. Please run a regular old F1 frame please. You can make them drive just fine, and they are easy to lower if you want. Also, the F1 body will bolt right up with no modifications whatsoever.
    JW
  8. 1great40
    1great40
    from Walpole MA
    Yeah, you would never be able to do this...[​IMG]
    and take a bunch of old and repop Ford parts like this...[​IMG]
    And somehow fit them together like this....[​IMG]
    And you wouldn't be able to fit the rest of it like this...[​IMG]
    And then it wouldn't be possible to get a result anywhere near this....[​IMG] 'cause a Ford Ranger frame has too many weird shapes.
  9. Johnny Wishbone
    Johnny Wishbone
  10. tfeverfred
    tfeverfred
    It's gonna get quiet now.
  11. kracker36
    kracker36
    Another option is an 80's Mazda frame. It is pretty simple and has torsion bars. Worth considering if the original setup isnt available.
  12. Zapato
    Zapato
    If you can find a 98 or newer frame you'll find the ride is much nicer.
  13. Sphynx
    Sphynx
    from Central Fl
    Dont have pics but Draggon Breath has a 47 IHC on a Ranger frame. Turned out nice.
  14. Cool, now 80's-90's Ford Rangers are traditional..
  15. damagedduck
    damagedduck
    from Greeley Co
  16. Bigchuck
    Bigchuck
    from Austin, TX
    You will have a early F1 Fazda.
  17. Verbal Kint
    Verbal Kint
    from Washington
    I knew it would never work
    I should have read this before Greg and I wasted 4 whole days using a running ranger as a donor... and now I'm too busy driving it to go back and change my evil ways
  18. ChefMike
    ChefMike
    what rear end did you use on the 47 ford ? I
    have a 47 ford and looking to put in a new rear axle
  19. Hackerbilt
    Hackerbilt
    Those trucks don't count...they aren't F1's! LoL
    Isn't/wasn't there already a big thread about this exact swap?
    I'd do it if the truck/frame were rusted really bad or something...but mods to the original frame are easy so a good truck I'd reuse the original.
  20. Ole don
    Ole don
    Yup, all ya gotta do is tell some back yard dude who has been hiding his skills that it cant be done!
  21. flynbrian48
    flynbrian48
    That's a pretty truck. I didn't know anybody built a 'gl*** '40 truck cab, you did a great job.
    Brian
  22. Kenneth S
    Kenneth S
    That's a U.S. body source cab that's designed to fit a Ranger ch***is (they have a complete 40 Ford PU body kit to fit a Ranger ch***is). U.S. body source does make some good fibergl*** (and some steel) products http://usbodysource.com/
  23. TERPU
    TERPU
    No drama intended here or needed. But an F-1 Frame is a really good foundation for the F-1 truck. The mint green one is a really pretty truck, but it also took a totally different frame on a Ford one, and that truck looks like it was designed for the Ranger stuff. The '46-'47 turned out great as well, but if you have an F-1 with an F-1 Frame you are already ahead of it.
    Tim
  24. Hackerbilt
    Hackerbilt
    Thats pretty smart!
    Ford did the exact same thing when they designed the original F1 frame!
    Hard to go wrong when you use a frame and body designed for each other. ;)
  25. tfeverfred
    tfeverfred
    So, you'd have to cut up an original cab for it to work?
  26. flynbrian48
    flynbrian48
    No wonder it fit the lumpy Ranger frame so well. So, the lesson here still is, use the frame that fits the body, unless you want to lots of needless work, or have a body with no floor or body mounts left.
    Brian
  27. I'm not totally anti frame swap. But why would you choose a twin I beam? I worked on these when I did heavy collision. If that frame didn't have so many bends and lumps it wouldn't be able to hold up it's own weight. The dreaded S10 is a far better design.
  28. Verbal Kint
    Verbal Kint
    from Washington
    I doubt we could have managed to end up with a running, driving, PB, PS 5 speed daily driver, stock seat, stock floor, etc... in less than 50 hours no matter how "cherry" the frame started out.
    For me this was a simple short cut, I needed a quick cheap replacement daily driver. This left me more time and money to work on the '32 for my dad and my '52.
    It helps that Greg has done several of these swaps and has the recipe pretty well down.
    The S-10 would have required firewall, lower cowl and floor channel work for fitment where the frame flares to the front suspension.
  29. Johnny Wishbone
    Johnny Wishbone
    I don't care how easy it may be or how nice it might drive, I just like using the original stuff. I have a 51 F1 all stock, drums all around, and a 51 F1 with a 9 inch rear and my own homemade disc brake conversion on the front on an original frame. Personal preference I guess.
  30. kracker36
    kracker36
    S10's are traditional because they came with a SBC 4.3:eek:
