Technical Ford Retractable 4 Wheel Disk Conversion Help!
Discussion in 'The Hokey Ass Message Board' started by barry smith, May 25, 2020.
  1. barry smith
    barry smith
    from Houston
    I realize this may have to be posted somewhere else but did not see a brake section.
    I have completed the conversion, Willowood front , Inline tube rear with large spin out caliper pistons in rear, dual pistons front.
    22 inches vac, 1979 Corvette style master cyl 1 1/8 inch bore., 8 inch dual diaphragm power booster,
    new 3/16 nickle lines, pressure bled system after installing everything and bench bleeding master.
    Adjusted pedal for 4-1 travel and have hard pedal about 2.5 inch from floor, still car will not panic stop or hard stop for that matter, definitely would not drive.
    Any ideas?
  2. grdra1
    grdra1
    Was there a gap between booster and master cylinder push rod. Glen
  3. birdman1
    birdman1
    A smaller diameter master cylinder may help.
  4. jaracer
    jaracer
    By "hard pedal" are you saying there is no ***ist?
