Technical Ford Shifter ID
Discussion in 'The Hokey Ass Message Board' started by Malcolm Elvy, Jan 6, 2023.
  1. Malcolm Elvy
    Malcolm Elvy
    Can anyone ID this shifter for me....Ford Toploader? 4 speed? Thanks for any help..
  2. 51504bat
    51504bat
    IIRC the factory Ford toplader shifters had a reverse lockout release below the shift knob.
  3. squirrel
  4. DDDenny
  5. DDDenny
    Not a Ford guy but it appears the early 60's Fords used the "T" style for reverse lockout but some of the later 60's did not use it.
  6. Malcolm Elvy
    Malcolm Elvy
    Thanks for information...Mac
  7. Four-speed with a three-speed lever....
    Ford used the same shifter ***embly for both the T10 and Toploader, just switched the trans levers and shift rods for the specific trans use. All Ford-built four-speed shifters had a reverse lock-out, the early ones used the 'T' handle, the later ones a sliding knob.
    There were also three distinct mounting brackets. Front mount for the '63-65 Falcon/comet, mid-mount for Fairlanes and some full-size, and rear mount for the Mustang and some full-size. The one pictured is a rear mount.
  8. Malcolm Elvy
    Malcolm Elvy
    Thanks to all for your help....Mac
