Hot Rods Ford "Short" Oil Filter?...
Discussion in 'The Hokey Ass Message Board' started by seadog, May 24, 2015.
  1. seadog
    seadog
    'Having clearence issues between the Vega box and the oil filter in my Deuce roadster with a 289 Ford. I hear there's supposed to be a "short" oil filter that can possibly solve this problem.
    Can anyone give me a part number for this filter? I did a search but all I can find is several references to a short filter, with no specifics. 'Need to know brand/part numbers. Thanks!
  2. swifty
    swifty
    Yes we have them here in Australia and I know the number for the local suppliers but don't know what a US part number would be. Got a box in the shed which may have a Fram or equivalent US number on it. Will check tomorrow if you don't get a suitable reply.
  3. Chrysler and Ford filters interchange. There is a short Chrysler filter. I think the Fram number is PH-43. Pretty much everything Chrysler, Dodge in the '80's took it.
  4. seadog
    seadog
    Swifty,
    Thanks...I found what I need on another HAMB tread. Turns out I was using the wrong search terms.
  5. gnichols
    gnichols
    from Tampa, FL
    I can't recall the number either, but they aren't too hard to "finger out" using the catalogs / computers in the filter aisle. Just look up / select a few filters that fit, say 5.0s, over a small selection of Ford vehicles and the "short box" will be easy to spot. Then compare their O rings for size, to be sure. That's how I found the filter for my 37's 5.0. They were Purolators. Someone told me that shorties were used on police cars (try Crown Vics) because they were changed so often that it didn't make sense to use a larger, more expensive filter. Gary
  6. maplefrm
    maplefrm
    from Central IL
    I use a K&N HP 2004 on my 302
  7. gnichols
    gnichols
    from Tampa, FL
    I forgot that, yes they do! I've also heard the stock Dodge filters are far better than aftermarket filters, too, but pricier. Gary
  8. Don's Hot Rods
    Don's Hot Rods
    from florida
    I've run the very short one on the sbf in my 27, it was a Volvo filter. But now I run one off of a 5.0 Mustang.......it is slightly longer than the Volvo version. I don't remember the Volvo number, but it can be found in the book they keep by the oil filters at the parts store, it fits most of the mid 80's Volvos, as I recall. It is really short.
    I was working on my 27 yesterday and had the Mustang one in my hand, but I didn't look at the part number on it, but if you need it I can look for you.
    Don
  9. denis4x4
    denis4x4
    from Colorado
    NAPA Gold #1068
  10. junkyardjeff
    junkyardjeff
    A mid 90s F150 or 250 with the optional oil cooler has a shorter filter.
  11. Engine man
    Engine man
    from Wisconsin
    Don't count on that. Filters are outsourced and many filter manufacturers put different brand names on the same filters.
  12. Turbo26T
    Turbo26T
    I use a Motorcraft FL-300.."short" filter...Advance Auto stocks them
  13. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Thats what my 94 uses. 1994 F150 351W with optional oil cooler, sometimes they list it as a tow package in the books. It uses the shorty.
  14. chessterd5
    chessterd5
    from u.s.a.
    I ran into this problem when I had my 302 in a model T. The shorty filter I used to clear the stock frame was a Fram PH-16 for a Dodge. thanks
  15. Deuce Daddy Don
    Deuce Daddy Don
  16. Screw short filter remote is the only way to go. Put it where the filter doesn't offend anything and run the biggest filter you can find.
    6-bangertim, 69fury and Andamo like this.
  17. Engine man
    Engine man
    from Wisconsin
    Why you should avoid Fram filters.
  18. cbillelder
    cbillelder
    Can't recall the filter number at the moment, but the '70s Mustang IIs with the 302 V8 option used a shorter filter.
    That's what I'm using on my '38 with a Mustang II front end.
  19. Hamtown Al
    Hamtown Al
    Purolator L10101 is 2.75" from mount to tip of filter. Napa 1335 is 2.5" from mount to tip of filter.
    Hope this helps. I run the Purolator filter on my Ford powered cars and I can get them at Advance--sometimes they have to order them for me. I can plan one day ahead... but it is a challenge!!:rolleyes:
    We need some measurements on the other filters mentioned to help compare them.
  20. finn
    finn
    My old 4L awd Aerostar called for the short Motorcraft filter, and I think my wife's 95 Mustang GT with a 5.0 calls for one too. Don't recall the numbers, but look for those applications in the catalog hanging near the filters..
    Also, one of the will fit filters, I think it is Quaker State or maybe Purolator sells a really short and small diameter filter under the same application. I actually thought I read the catalog wrong as I held the tiny little filter in my hand. I immediately thought of space constrained engine swap possibilities.
  21. Bakchoy
    Bakchoy
    from georgia
    Just go to Wixfilters.com and click on contact and tell them what filter your engine uses and that you need a shorter one and they will give you the part number and dimensions of the shorter filters. You should be using Wix filters anyway. jmho.
    69fury likes this.
  22. seadog
    seadog
    Lots of good info here. Thanks. 'Will go to the parts store tomorrow as soon as it opens.
  23. OLDSMAN
    OLDSMAN
    The Police cruisers used a short filter because there was an oil cooler adapter that went between the block and the filter. It was a clearance problem to use the FL-1A filter so they used a short filter, I can't remember the Ford number on that filter
  24. Primered Forever
    Primered Forever
    from Joplin,MO
  25. Primered Forever
    Primered Forever
    from Joplin,MO
    I used the FL2005 Motorcraft filter on my A. It is shorter and it is smaller diameter than the FL300.
  26. LOL I have run Fram Filters since I was a kid and have never ever had a problem with one. I have read a lot of bad about them though. ;)
  27. OLDSMAN
    OLDSMAN
    Yes, a FL300 was the number on the short filter, my memory is getting short
  28. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
  29. Dave Mc
    Dave Mc
    another solution is this 90* adapter, sold by Ford Mo Co OilFilterAdapter.jpg
  30. Wix actually makes a pretty good filter. I can still remember when we called them farmer filters around here though. Used to be that they were cheap and mostly got used on tractors and farm trucks. :D
    Then they started sponsoring short track guys and got a better reputation from there. Maybe it was different in other parts of the country.
