Hot Rods 1964 Ford side loader transmission parts
Discussion in 'The Hokey Ass Message Board' started by Kiwi 4d, Oct 7, 2025 at 11:33 PM.
  1. Kiwi 4d
    Kiwi 4d
    Does anyone know where to get a ford side loader transmission drive gear (green) it’s a one off year 64 , 4 speed , with the Speedo on the drivers side (LH) entry it has a 16 tooth driven gear . Thanks
  2. Oneball
    Oneball
    Is it the same speedo gear as the C4? They are left hand out put too.
  3. Is the trans a Borg Warner t10?
  4. HOTRODPRIMER
    HOTRODPRIMER
    Try David Kee
    https://www.4speedtoploaders.com/
    Some of the items and services we offer
    4 Speed Toploader Parts
    Hydraulic Throwout Bearings
    Clutches, Bellhousings & Flywheels
    Shifters
  5. vtx1800
    vtx1800
    For what it's worth....back in 64 an acquaintance bought a new 64 Galaxie with a police 390 and four speed, it was a Borg Warner T10 (as I remember), it didn't last long, and one breakage was covered by warranty, he replaced it with a top loader not long after. I'd wonder if common T10 speedo gears would be the same?? If that assumption is correct I did find the blue gear (and maybe that is all you found too?) at this vendor. https://www.allstategear.com/T10-Speedo-Gears-s/2152.htm and for yellow...https://www.ebay.com/itm/1858457482...9SWXi8+lFS0/kkLlLLpc2NvFJXw=|tkp:BFBMmu2DyLhm
