Hello, I'm new to this message board. And I'm glad that I was told about it! But anyways. I'm running a modal A axle with modal A spindles. But I want to run juice brakes. Can any Ford juice backing plates bolt to the modal A spindle. If so what years? And if not what would you guys do to get juice brakes on an A axle. ( THE CHEAPEST WAY )... Thanks, Ronnie
There is a very good brake thread in the tech archives that will answer your question better than I can. There is also a search feature here as well. And you can use it to research questions before you ask.
