Ford Steel Wheel Tech
Discussion in 'The Hokey Ass Message Board' started by wheelkid, Jun 16, 2006.
  1. 50Fraud
    50Fraud
    Wide 5 wheels use clips (see the first post in this thread). You're probably right about all the 5+1/2 BC wheels.
  2. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    wide fives and lincoln wheels had clips
    Jimmy
  3. lotus
    lotus
    from Taft, CA
    I wonder what these are off of. They are 15x7 5 lug 4.5 pattern.
    some of the gas stations around here have them for $10 bucks a pop.
  4. duste01
    duste01
    If they are from the gas station, they came from off the shelf, they look too clean to have come from off the wall, or from holding the hose off the floor.
  5. Wheelkid, if i wanted to turn my pickup 5.5 wide wheels into 4 or 4.5 wide wheels, can i use my pickup centre and put a wide 5 outer together? Assuming there is a rivet holding the centre into the wide 5 for aligning the centre to the outer.
  6. stealthcruiser
    stealthcruiser
    Hard to tell........Do they have threaded holes between the lug holes?????
    Possibly Mopar, mid to late '80's Diplomats and the like..........May read "Kelsey-Hayes" on them somewhere.
  7. Bruce Lancaster
    Bruce Lancaster
    There are more sizes and types of the early (1948 and back) wheels than most realize...there are several early Lincon wheels, some funny early Merc sizes, and there are two similar wider 16's for pre-1948 and post 1948 1/2 ton...
    I have turned up early Merc and Lincoln listings and will try to list'em all out whenever the early V8 guy gets done with the blasted Merc catalog. All thge part numbers are worthless, of course, but the list might ID the odd finds.
    All the Merc and Lincoln variants surprised me!
  8. alchemy
    alchemy
    I've got 16" Ford-style inner-knob steelies in 4, 4.5, 5, and 5.5 inch widths. I might even have a 6 inch wide wheel somewhere. It seems that there are a myriad of weird applications for these wheels, and I'd guess NOBODY has ALL the correct application info. Probably a lot of over-the-counter stuff.
  9. HotRod33
    HotRod33
    Thanks for the info now, I can figure out some of the wheels that I have.....
  10. Alot of the ford wheels I have found have a small ford script between two of the lug holes and are stamped ford on the inside between the beads. How far apart are the lugs that hold the center cap on. If they are ford wheels Im jealous, cant find any around here. PM me if they are ford and you want to unload them.
    Brad
  11. vertible59
    vertible59
    Was there a '50s Lincoln 14" wheel, 5on 5.5 bc?
  12. 302GMC
    302GMC
    from Idaho
    The '58-'60 Lincolns supposedly used 14''s ... we always used '57 Imperials instead
  13. vertible59
    vertible59
    Thanks, 302 GMC.
  14. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    Unfortunatly no, the rims have different IDs
    There is a lot of stuff I missed in this tech, I should go back and update it as best I can. For instance, That 16" wheel with the clips and not a lincoln, It's an aftermarket wheel for 28-35 Fords because it has the two step bolt pattern plane like 28-35 Ford wires do
    I've never seen a 5.5" or 6" wide 16" wheel, I'd like to see a picture of one or some part #s if you can.
    Jimmy
  15. Bullrack
    Bullrack
    from Louisiana
    I just got a nice set of my Dad's '55 Merc K-H solid center wheels. He rolled the car in '59 end over end and never damaged a wheel. He pulled all 5 wheels and put them up. I'm in the process of reversing 2 as we speak, so I can post pics later. They are pretty damn cool wheels. Steven.
  16. striper
    striper
    Now you've got me curious. I bought a donor 48 Ford chassis to build my 28A. I am using the axles and wheels among other bits.
    The wheels are 16" with 5 on 5 1/2 bolt pattern. The rims on these are stepped both back and front.
    I have another set of similar wheels that are also 16" and I think a bit wider but they have the step on the front and the tapered back on the rim.
    Are my first ones 48 Ford? Are the second set pick-up of some description? I think that was what was marked on them when I got them at a swap.
    Pete
  17. knotheads
    knotheads
    they look like late model crown vic
  18. Dirty Dug
    Dirty Dug
    Those are '39 Lincoln if they are actually 5-1/2" inside, very rare and expensive if someone knows what they're selling. The five inch wide '40 style wheel, I think, was used on trucks up into the early sixties. I once found a pair in a junk yard for two bucks a piece. But what I passed on, not knowing what I was looking at, was an old International truck with 16" Ford style wheels with a 4-1/2" bolt pattern, perfect for a later Ford rear end.
  19. paulie_boy13
    paulie_boy13
    from NC
    whats the backspacing on the 49 Ford 15x5 wheel?
  20. striper
    striper
    I think you mis read my post. My wheels are 5 on 5 1/2 bolt pattern, not 5 1/2" wide.
    My question came mainly from the difference between my 2 sets. One with the stepped rim at the back, the other with the tapered rim.
    Pete
  21. I have both 5.5 wide wheels with the step and the taper, both sets came from 53 to 55 f100's.....so I am puzzled also :)
  22. Paul
    Paul
    Editor
    I just picked up a pair of... well one '49 and one '50 Lincoln wheel
    that take the same size dog dish cap as the Mercury
    and also has the "bumps" in the rim for the stock full cover
    6" wide Lincoln on the left and 5-1/2" wide Merc on the right
  23. lotus
    lotus
    from Taft, CA
    I never really noticed all the differences in the two 15X7 5 on 4.5 lug steel wheels I have. I know one pair has extra little holes between the lugs. That pair does not say ford on the back. That pair has a smaller offset and also has a smaller ring in the middle where dog dis hubcaps would attach.
    The other pair have a larger offset, have ford stamped in the back and has a larger ring around the lug holes.
  24. Here's a couple more rims to figure out.
    15" diameter wide 5 rim: What was it off?
    15" x 5.5" w 5 on 5.5" bolt circle. Solid center, no slots, inside bumps for '40 style hub cap, Ford logo and KH stamp: What was it off?
  25. Bruce Lancaster
    Bruce Lancaster
    If the stepped vs taper wheels are both the normal early Ford width, I believe the stepped backs are 1941-48 and the tapered are 1940. O1A and 11A prefixes originally,,,the stepped wheel was the service wheel for both types.
    I think the Ford script indicates Ford made wheels, others are outside suppliers to Ford like KH.
  26. Hot Rod Bob
    Hot Rod Bob
    from T-ville Ky
    Thanks It's guys like you that make the HAMB so great!!!
  27. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    That 15" wide five is a later truck wheel, you should be able to find a date code and part number on the rim.
    I don't know what that solid wheel is
  28. 2-TONED
    2-TONED
    this is a good post.
    but i didnt catch what wheels (like pictured) came on what?
    pictured here 'blue is a 16x4.5 wide wheel with 3.5 back space
    & a green 16x4.0 wide wheel with 3.25 backspace.
    i always identify the 4.5 wide wheels (blue) by the full triangles between the lug holes instead of the sawed off looking triangles like the green wheels have.
    i do have a set of 5 1941 ford wheels that came off of a low mileage '1 owner coupe that im sure came on that car new they are the 4.0 wide style.
    i would liketo be educated on what wheels came on what & what year.
  29. alchemy
    alchemy
    Here's pics of the "rare" 16 x 5.5 steelie. Couldn't find a 6" wide wheel.
  30. Little Wing
    Little Wing
    from Northeast
    Were'nt Jeep wheels solid ?
