Technical Ford T5 speedo
Discussion in 'Traditional Hot Rods' started by Shoovel, Feb 11, 2023.
  1. Shoovel
    Shoovel
    Folks, My Hot Rod has a T5 out of a 92 Mustang (according to the tag) with a gear driven VSS. Does someone make an adapter to use an “old style” speedometer cable that screws onto the trans gear and speedometer head?
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    To my knowledge, not a "plug and play". It requires some modifications.
  3. 51504bat
    51504bat
    e1956v likes this.
  4. big duece
    big duece
    from kansas
    Is yours like the one on the left? Gear drive that is converted into elec. pulse? should just be able to switch out to mechanical bullet with cable end. The one on the right is for T5s that have a steel reluctor ring and magnetic pickup.
  5. nickleone
    nickleone
  6. e1956v
    e1956v
    Alliance Vendor
    I can make up a speedometer cable that fits the Ford VSS or I stock the 7/8-18 threaded adapter that takes the Ford speedometer driven gear to replace the VSS if you don’t need it to run fuel injection or something else.
    PM me or hit the link to the website in my signature. Give me a length for your cable and I can provide the works.
    big duece likes this.
