Ford TFI
Discussion in 'The Hokey Ass Message Board' started by mkrog1, Oct 23, 2010.
  1. mkrog1
    mkrog1
    from Austin Mn
    Does the Ford TFI distributor need a computer,if not how would one wire it?
  2. BulldawgMusclecars
    BulldawgMusclecars
    Yes, its designed to work with EEC-IV. Teh computer controls the advance.
    You'll need an older Duraspark if you want factory electronic.
  3. old lady's mad
    old lady's mad
    if you want advance yes , if not no. it is a perfect to use with a msd box. you can also use it with a duraspark box just like the old dist. but you will have no advace . simple to wire. one wire is a dist. body ground. the other 2 are the pick up . use an ohm meter to find the ground by putting one lead on the body and to each of the wires inside the plug.
