Ford Top Loader Help.
Discussion in 'The Hokey Ass Message Board' started by Montechris, Feb 19, 2007.
  1. Montechris
    Montechris
    I'm taking apart a 1938 Ford Toploader to make a "39 style" trans. I'm trying to get the clutch fork off the shaft and I dont want to ******-up the pin. Every other toploader I have taken apart i used a punch to do this, but usualy the punch breaks from being too small or the Pin mushrooms from using too big of a punch. Anyone have any tips?
    Thanks,
    Chris
  2. Kevin Lee
    Kevin Lee
    Super Moderator
    This is going to sound like I'm being a complete *** but... could you just try using the correct sized punch? :confused: :)
    I drill the top off before I go after it with a punch and hammer.
  3. Montechris
    Montechris
    Yes, that is crazy talk.. lol.. sounds like a good idea, and it might be,,,,the Pin is concaved {\/} (sorta like this) making the sides easy to mushroom out. I should probably browse different punches. For now it's soakign over night.
    What do you mean by "drilling the top off"?
    Thanks,
    Chris
  4. qzjrd5
    qzjrd5
    from Troy, MI
    I use heat. Heat the area around the pin with a torch - don't directly heat the pin. Then use your punch - it will come out - I have removed a few of them like that.
    Mike
  5. Kevin Lee
    Kevin Lee
    Super Moderator
    I have a punch that works perfectly for this. It actually looks too big at first but it's the perfect size - just a few thousandths smaller that the pin itself. Carefully center it and a BIG sharp hammer blow starts it moving. I'm talking hand sledge and a serious commitment while completely trusting your aim.
  6. jetmek
    jetmek
    its a tapered pin. if you try to drive it from the front top it will get tighter.i drill a hole in the bottom of the bell and use a long punch to remove them.
