Ford toploader to chevy sb
Discussion in 'The Hokey Ass Message Board' started by coryz28, Jul 4, 2011.
  1. coryz28
    coryz28
    from tulsa
    Im looking for a bellhousing THat will mount a toploader 4 speed to a chevy sb, I hoping to find a bell to do this with, I know its been done just wondering what it will take. Thanks
  2. aaggie
    aaggie
    It was pretty common back in the day since the Ford box was stronger than the GM stuff. It shouldn't be hard to make a plate to go between the Chevy bell housing and the trans case. Drill and tap the holes and bolt them together. I think the Ford input shaft is longer so that would give you the thickness of the plate, then make a pilot bearing to go in the Chevy crankshaft and drill the center to match the Ford input shaft.
    Use the Ford clutch disk and it should be OK.
  3. seb fontana
    seb fontana
    from ct
    Lakewood may still make a bell but $$$ as it would be a blow-proof..Pretty sure also that if you do a search there is a company that makes all kinds of adaptor bellhousings, I got it stored somewheres, I'll post if found....
  4. George
    George
    Not to mention adaptors by Wilcap.
  5. seb fontana
    seb fontana
    from ct
    Ah, Wilcap...I keep forgetting that they are still around..My memory jogging some, SFI Industries?
  6. McCloud bell housing will work. Comes with the pilot retainer adapter ring. Speedway sells them >>>>.
