Ford tranny guys, need help.
Discussion in 'The Hokey Ass Message Board' started by kookie67, Feb 25, 2010.
  1. kookie67
    kookie67
    from Pa
    Hey guys, I've got a 62 falcon wagon with a 170 inline 6 and a 2 speed Fordomatic. The car wont shift out of first until you drive a while, but once it shifts, it will shift the rest of the day. Local ****** shops have no clue, any help would be appreciated. Thanks, JR
  2. BJR
    BJR
    Have you replaced the filter yet?
  3. kookie67
    kookie67
    from Pa
    Yes, It has a new filter, gasket and new modulator.
  4. Hnstray
    Hnstray
    from Quincy, IL
    Sticking valve in the valve body or, quite possibly, a governor problem??
    Ray
  5. Deyomatic
    Deyomatic
    from CT
    Does it have the right fluid in it?
  6. kookie67
    kookie67
    from Pa
    Someone else mentioned it might be a govenor problem, any advice on verifying it. It has new fluid, I'm pretty sure just regular old Napa fluid for fords. Thanks, JR
  7. kookie67
    kookie67
    from Pa
    Any other ideas?
  8. 38Chevy454
    38Chevy454
    Sounds like something sticking inside there. Put some trans-x in, it can help loose what is sticking. You should be using Type F fluid. Same as all the older Ford auto trans used.
